Quick Connect leaks + other issues
My Ride: 545i Sport
Finally got my newly installed motor up and running.
For my first phase of troubleshooting, I need to rid myself of all leaks. So far, I have no oil leaks
. But I do have a fuel leak and hydraulic leaks, and they are all at the darn quick connect links.
The fuel is leaking from the fuel rail to fuel line quick connect here:
![Name: wJxfZP2l.jpg
Size: 55.0 KB](https://5series.net/forums/attachments/e60-discussion-2/165124d1683047484-quick-connect-leaks-other-issues-wjxfzp2l.jpg)
I read a thread where it stated that you either have to replace the whole rail (not happening) or cut the connect off and put a new fitting on. Does anyone have any other methods to suggest?
Both the quick connect fittings for the hoses that connect to the power steering cooler are leaking:
![Name: B9AxjN0l.jpg
Size: 58.7 KB](https://5series.net/forums/attachments/e60-discussion-2/165125d1683047484-quick-connect-leaks-other-issues-b9axjn0l.jpg)
![Name: 31tGm0Bl.jpg
Size: 50.4 KB](https://5series.net/forums/attachments/e60-discussion-2/165126d1683047484-quick-connect-leaks-other-issues-31tgm0bl.jpg)
I also have a persistent exhaust camshaft code that comes back even after changing the camshaft sensor out.. This is the bank 2 sensor:
![Name: JTkiTDkl.jpg
Size: 57.1 KB](https://5series.net/forums/attachments/e60-discussion-2/165127d1683047484-quick-connect-leaks-other-issues-jtkitdkl.jpg)
Finally, I am looking for what sensor goes here on this hanging connector in the passenger wheel well as I have been unable to locate it via realoem:
![Name: 72Osenll.jpg
Size: 71.9 KB](https://5series.net/forums/attachments/e60-discussion-2/165128d1683047484-quick-connect-leaks-other-issues-72osenll.jpg)
Ideally, I'd like to repair the lines to be fit for use as they are quite expensive. The one on the drivers side will be QUITE a bit of work to get installed as well. I definitely do not wish to unbolt the engine and hoist it again..
Thanks in advance!
Thanks in advance!
My Ride: 545i Sport
BUMP
About to pull the trigger on these hoses but the return hose is really expensive ($200) and seems like a slight waste as the hose itself is not leaking, only the quick disconnect fitting..
