Question.....Please help
Old Aug 13, 2010 | 10:38 PM
willng103's Avatar
Hi Everyon
I just brought a 2007 BMW 530i.I'm going to put some m5 166 rims, Two front tires are size 255/40/19, and two in the back are size 285/35/19, Do i need any spacer?? Please let me know. So i can put it on this Sunday.
Thanks again and have a nice day!!!
Old Aug 13, 2010 | 11:00 PM
Kaizen's Avatar
My Ride: 2005 545i Alpine White Premium package, Sport package, Nav, HUD, PDC
Hi and welcome to the forum. I've been looking for a good used set of OEM 166s and from what I recall, spacers are recommended. Do you know which offset you have? I think those come in a M6 offset as well, as style 166 wheels are offered as an option for the M6. I could be mistaken though I'm sure the well informed will chime in soon.
Old Aug 13, 2010 | 11:09 PM
e6t.lab.rat's Avatar
With OEM M5 166, spacers are not necessary though the stance will look a lot better with it.
The fronts are running a little wider than what's recommended (245/35) but will fit. I think the back tires are just right however, the recommended size is 275/30. I believe the tire sizes might be a bit too tall.
As far as spacers go, it's not necessary but would look more aggressive. If you do decide to use spacers, go with 15mm in rear to get flush with the fenders or, 12mm (like me) to be a little "tucked." Keep in mind my rear tires are only 275. Your 285 will definitely be closer to the fender so 12mm might do the trick.
BTW you joined in 2008 and only now is your first post?! wow Very belated Welcome!
Old Aug 13, 2010 | 11:15 PM
You're right. They come in two different offsets, one for the M5 and the other for the M6. With the M5 offset the rears are set further in the wheelwell than the M6. The M6 almost sit flush to the fenders. The front wheels are identical on both. If you dont want to deal with spacers than M6 offsets are the ones you want.
Old Aug 14, 2010 | 01:28 PM
willng103's Avatar
Hi
What size of tires i should buy for the front and back????
Thank you so much for your wonderful information.....!!! I'll post some pictures when im done....!!
willng103's Avatar
Hi
Old Aug 14, 2010 | 01:36 PM
Gene's Avatar
Originally Posted by willng103
Hi
this thread is good reference for choosing tire sizes...
https://5series.net/forums/topic/545..._1#entry575726
most have the recc'd tire size in this thread (including myself with 166's, M5 offsets...)
Old Aug 14, 2010 | 10:44 PM
willng103's Avatar
Thank you so much for your information.......I was going to pick up the rims today after work ,the guy sold the rims...... SUCK, but if you know someone are selling the OEM M5 166 Rims, please let me know.
