Question on battery chargers -- what good?
My Ride: 530ix
Model Year: 2020
I tried to google this but it has not really answered my question.
My BMW battery is about 5 years old (yes, probably time). The little sensor window on top is black, thus it always states "not fully charged" even after a long 1 hour drive. I normally drive about 20 minutes to work every day.
I ended up with a free [URL=" and it says it can repair AGM batteries. Should I try this? do I need to remove the battery from the car or can I just hook it up to the positive and negative lead on the battery? Instead should I use the positive post under the hood and the body?
can this thing bring my battery back and put the little sensor window on the top back to green fully charged?
I realize the normal application is for people who store their cars, but it mentions it heals batteries. I am not really the store car type and have no experience with this.
Ireally to get another 6-12 months from the battery would be nice. right now I am about to flush the transmission and after Christmas will replace the water pump. would love not to also need the battery now...
thanks
thanks
Forget about repairing a battery. Go online and find a $40 off coupon for Advance Auto Parts and get the same size AGM from them you have in the car now. Should cost you like $140 if bought online and using the coupon. I think the current one is slightly more powerful than the one you probably have, but the specs are pretty similar. Then install it and get the battery registered.
My Ride: 530ix
Model Year: 2020
the question is which AGM to get? they have like 3 of them and the older posts reference models that no longer are sold.
First go see what kind of battery is in the car now. I'd just stick with the same type (i.e. AGM or non-AGM). Get the BMW part number off the battery. See if that is AGM or not. See what the AH rating is.
Wife's 2009 X5 already had an AGM and took this one from Advance Auto:
AutoCraft Platinum AGM Battery, Group Size H8, 900 CCA H8-AGM: Advance Auto Parts
If you install it be sure to install the vent tube correctly and plug the vent one on the other side.
My Ride: Sold: 545i, sport package, cold weather, 6MT
Engine: N62
20 minutes should be enough to recharge your battery during your commute, as you seem to have suspected, so I guess you're at the end of the road with this battery.
I have a fairly new AGM battery and Valeo alternator, and if my battery is on the low side I can run it on the highway straight for an hour, come back and throw the Battery Tender on it and I am still not even at an 80% charge.
After fully charging with the battery tender and eliminating plate surface voltage, a healthy battery should measure 12.75V +.
Awest91
09-17-2022 11:05 PM
