Push button won't start
Old Dec 23, 2010 | 02:01 AM
tranm4's Avatar
I tried to turn on my car this morning and it won't start when I turn on...so I then try to jump start it and still didn't turn on...so I then try to turn on with out jumping it and it finally work...When I was about to go to leave work it didn't turn on and it was raining hard....it has been raining for about 5 days straight...any I dea what's wrong with it??
Old Dec 23, 2010 | 02:14 AM
turboawd's Avatar
My Ride: 2006 BMW 550i
what exactly happens when you try to start? does the engine actually turn over? or nothing at all?
Old Dec 23, 2010 | 04:24 AM
kane1111's Avatar
My Ride: Navy 550I
It's probably pissed that it rained for 5 days on her..lol Good luck tho..
Old Dec 23, 2010 | 08:14 AM
tranm4's Avatar
It just won't start.it doesn't do nothing...it wont even get to the part to open the sunroof with out turning the engine on and it usually does...to do that you put the key in and just press the start button without stepping on brakes...also it just won't go on neutral..I am a platinum member at aaa and they cant even tow my car because its to luxury...smdh....what does that have to do with it...I'm all piss off about them...right now I'm at the point of getting rid of it...my car is still at the office...don't know what I can do..
Old Dec 23, 2010 | 08:59 AM
turboawd's Avatar
you try a different key fob?
thats strange.
Old Dec 23, 2010 | 09:12 AM
luigi524td's Avatar
You best check for water leaking into the area under the spare tire well. Sounds like you may have a collection of electrical problems and that is a known problem area with lots of electronics stuff.
Old Dec 23, 2010 | 11:02 AM
tranm4's Avatar
Wow you are right..im looking at the battery and there is a leak going inside.i had an accident in the rear and it looks like they put the vent going inside instead of going outside so the water is going in the battery...
Old Dec 23, 2010 | 11:06 AM
balbs's Avatar
My Ride: BMW
As stated earlier, check in the spare tire area as well for water. Depending on your model, the micro-processor might be there getting soaked.
Old Dec 23, 2010 | 11:16 AM
ponnu's Avatar
If you see water in spare tire compartment in the truck 'DO NOT TRY TO START the car', you need to dry it first and make sure none of the electronics are fried..
Old Dec 23, 2010 | 03:52 PM
leese8080's Avatar
My Ride: 07 530i Mystic Blue
Water going into the battery? Holy hell.. That sounds dangerous.
