Punctured tire?
![Talking](https://5series.net/forums/images/icons/icon10.gif)
Hi everyone,
Last night got this came up: Punctured Tire warning. Checked all tires, seems fine. Left it standstill for 24 hours - same.
Just wanted to find out what else i can do to make sure tires are ok before i reset my idrive? I dont really fancy going back to BMW and paying large sum for tire check, my tires are just 3 month's old!
Thank's in advance
Thank's in advance
Originally Posted by biotoxic' post='635847' date='Jul 30 2008, 09:09 AM
Hi everyone,
Thank's in advance
Thank's in advance
Did you check the tires via tire gauge? Might be a good idea to do that as well, you could always take it by a local tire shop and have them check the tires. GL
Did you check the tires via tire gauge? - how do i do that??
And to mhs525 - my car is 2005, this warning came up first time, and tires look fine, pressure fine..
Thank's for responses guys
My Ride: 2007 530d M-Sport Auto, Individual Spec (Ruby Black Paint, Champagne Nappa Leather, Piano Black Trim), Media Pack (Navigation Professional, Bluetooth, CD Changer, Voice Control), Sun Protection Glass, 19" Style 172 Rims, Hi-Fi Speakers, Heated Seats
Hope I'm not stating the obvious here, but if your tyres are runflats, they will not 'look' deflated even if they are punctured.
Only way to be sure is to check them with a tyre pressure gauge (e.g. like the ones at a petrol station...) to see if any of the 4 tyres are below the recommended PSI (or Bar).
Alternatively, any tyre outlet should be able to do this for you as well, free of charge.
However, if your tyres are not runflat and they seem fine, then it's likely the message is an error so you should be okay just resetting the I-Drive. Still a good idea to check the pressures though.
Hope this helps.
My Ride: 04 grey 530i..mods so far are pretty basic stuff- 20% tints, 20" Cattivos, Eibach springs, 8000k xenons (pics to come)
Originally Posted by Get One' post='636024' date='Jul 30 2008, 07:03 PM
tire gauge is the tool used to check the psi in the tires ( usually silver, you put it on the tire valve and it shows the psi reading. . i think probably the wording maybe different in UK thats why you were confused. Im sure you used one to check the tires.
OK! Now i get it! Of course i have used pressure meter (tire gauge).
Once again - cheers for help on this, much appreciated!!
carid
04-10-2015 01:59 AM
browellm
04-22-2004 11:31 PM
