pulsing rear end vibration at highway speeds
Old 05-09-2014, 10:07 AM
Bill109's Avatar
My Ride: 2005 525i 6MT
Originally Posted by tonyb635
Oh that SUX! To answer your question I did not change the center bearing, just the rubber disc.
this wil be differential number 3. wtf.
original was number one, a replacement when i bought the car was two. and this one will be three.
any ideas on gear ratio for a 2005 525i manual? 3.23? does the diff have to be transmission specific?
Old 06-03-2014, 05:04 AM
bmrboi2's Avatar
My Ride: 2007 530xi CPO
Default Sounds like the same problem on mine.
Not to Hijack but I have an 07 530xi with 38-ishK miles on it and Im getting the same thing. Its got such low mileage I just couldn't believe it was a differential or even the flex disc and bearing. It is driving me crazy. Was thinking of having the wheels balanced first. The wheels have been repaired....previously and Im assuming its that but I was wondering if anyone had any input on it or if its even remotely likely that there is something mechanically wrong with it.
Old 05-02-2016, 01:09 PM
PeeweeCSHL's Avatar
My Ride: 2008 550i mSport
Bill, did you find out what was causing the vibration?
Old 05-03-2016, 09:40 AM
frchdragon's Avatar
My Ride: 05 530i
Originally Posted by Bill109
Found out today the diff is going bad. Rear wheels are bent.
So I have to spend 2-300 on straightening the wheels first..
What I do not understand is the fact that you said that you tried 3 different sets of rims... Are all your rims bent???
An harmonic vibration is usually caused by tires or rims. Every time I had an harmonic vibration that I felt in the rear end, the tires were the issue.
Old 05-08-2016, 02:44 AM
kalacho2006's Avatar
My Ride: 2004 BMW 525i
I used to have this vibration when i get the car, car come with aftermarket wheels and had a bad vibration up to 60 MPH i just bought a set of aluminium hub centrics to center the wheels and vibration is gone maybe that can be your problem.
2004_545i
03-19-2015 12:15 AM
jcolley
03-17-2015 09:15 AM
coops
10-07-2003 04:45 AM
ISUK
08-21-2003 06:12 AM
08-12-2003 11:41 AM
Quick Reply: pulsing rear end vibration at highway speeds
