Proper idle speed
My Ride: 2009.5 E60 550i MSport
2011 E90 ///M3 ZCP
Proper idle speed
Hey guys, so my 550 has been acting a little 'weird' recently. It feels a bit sluggish. I've had an oil change done and replaced my filters not that long ago. I've notice that the car trembles a bit when I have the wind/ac totally off. it has a deep rumble, the motor seems unstable/trembles. The car is idling at a needle/hair under 500rpm full stop in drive, my M3 idles at around 600-700rpm full stop,
any clue?
any clue?
Years ago, I had a '85 6 series coupe. Like you, after having the oil changed, the car exhibited the same symptoms. As it turned out. The oil dip stick was not completely plugged in causing a vacuum leak. effecting the oxygen sensor function.
It may just be due to a vacuum leak??
any clue?
any clue?
If the idle is below, I would check for vaccum leaks such as oil cap, crankcase hoses, etc.
2011 E90 ///M3 ZCP
My Ride: 2008 550i sport package
You may need to put soapy water on all the hoses and connections to determine whether there is a leak. Sometimes a visual inspection won't reveal the problem.
i had the same problem on my 2007 525i, took it to my mechanic and he raised the idle about 100 rpms and now it feels perfect. also got my spark plugs changed at 98k miles. hope that helps
My Ride: 2008 550i M-Sport
On my car the rpms were acting weird until they did the vacuum line (brake recall). Now it idles perfectly at 500, A/C off. 750 with the A/C on.
Item Affected: SERVICE BRAKES, HYDRAULIC OWER ASSIST:VACUUM
Date Announced: 10/1/2010
Description of Recall:
BMW IS RECALLING CERTAIN MODEL YEAR 2004-2010 5-SERIES, 6-SERIES, AND MODEL YEAR 2002-2008 7-SERIES VEHICLES. A CHECK VALVE OF THE BRAKE VACUUM PUMP MAY LEAK A SMALL AMOUNT OF LUBRICATING OIL. OVER TIME THIS COULD RESULT IN CONTAMINATION OF THE BRAKE BOOSTER.
Action Needed To Fix It:
BMW WILL NOTIFY OWNERS AND DEALERS WILL REPAIR THE VEHICLES FREE OF CHARGE. THE SAFETY RECALL BEGAN ON NOVEMBER 24, 2010. OWNERS MAY CONTACT BMW AT 1-800-525-7417. "
http://www.dealerrater.com/recalls/BMW/5-SERIES
alienintelligence
09-07-2015 12:09 AM
