PROGMAN v25.xx hits the BMWNA shores
SI B 61 14 03
General Electrical Systems March 2007
Technical Service
This Service Information bulletin supersedes S.I. B61 14 03 dated December 2006.
designates changes to this revision
SUBJECT
Software Errors Corrected with Progman
MODEL
E60, E61 (5 Series)
E63, E64 (6 Series)
Vehicles produced up to February 28, 2007
SITUATION
Customer may complain of the following:
The following software errors were corrected with the release of Progman 25.00.00 (Target data Status E060-07-03-510).
Engine pinging and cold idle fluctuation complaints. A jolt may be felt under braking. Only N62TU.
CCC: The programmable diamond MFL button does not work when set to "Next entertainment source" when vehicle is in motion.
CCC: The customer occasionally has poor radio reception after the vehicle was programmed with Progman V23.x or V24.x.
The speedometer and tachometer needles shake when the vehicle is idling.
CCC: Slow response to inputs made when using controller after startup.
CCC: A high frequency whistling noise intermittently can been heard in radio mode
CCC: Navigation system pop-up arrow display missing. Refer to SI B84 61 06.
CCC: CD/CDC track advances after key cycled. Refer to SI B65 32 05.
PROCEDURE
For all vehicles, on a customer complaint basis only, refer to the following procedure and warranty information.
Update the complete vehicle per SI B09 05 01 (Coding, Individualization, Programming) Procedure B, using Progman 25.00.00 ( Target Data Status E060-07-03-510) or higher.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code
Refer to KSD
Labor Operation:
Refer to KSD
Technical Service
SUBJECT
MODEL
E60, E61 (5 Series)
E63, E64 (6 Series)
SITUATION
PROCEDURE
Defect Code
Refer to KSD
Labor Operation:
Refer to KSD
My Ride: 2005 545i, Orient Blue/Beige, Navigation, Premium Sound, Cold Weather, PDC, split-folding rear seats, DIY iPod. DIY Valentine 1 hardwire, loose nut behind the wheel.
![Cool](https://5series.net/forums/images/icons/icon6.gif)
SWEET JEEBUS! This is the document I've been waiting for. Three cheers for cobradav!
Excellent info ... I just made a service appointment for April 4th, for which I noted some lingering symptoms of periodic engine pinging, cold idle fluctuation, and slow response to i-drive inputs.
Hopefully these will unquestionably lead to Progman 25.
Thanks Cobradav!
Thanks Cobradav!
My Ride: 2005 545i step, nav, sport, 166 wheels, premium sound, don't need nothin' else.
Thanks Cobradav!
Thanks Cobradav!
I'm going to Field's BMW ... I won't know what they have until I talk to the service manager on April 3rd when I drop it off that evening.
I don't know how the updating works, but I presume it's a download process, so the dealer doesn't actually recieve a CD from BMW like other parts. Right?
Can anyone chime in on how this works?
![Exclamation](https://5series.net/forums/images/icons/icon4.gif)
Originally Posted by my530i' post='405777' date='Mar 22 2007, 05:30 PM
If someone can access bmwtis.com, he/she might be able to find out if Progman 25 is loadable. To be safe, call your SA.
