Progman 25 Landed in UK
#31
Originally Posted by sos' post='407698' date='Mar 27 2007, 10:40 PM
the new POI facilty is good
http://forums.e60.net/index.php?s=&sho...st&p=407637
ABC
#32
Originally Posted by aybeesea' post='407711' date='Mar 27 2007, 10:20 PM
Are we still limited to the display of a single POI type eg only fuel or only hotels?
ABC
ABC
#33
Originally Posted by the-oneil' post='405336' date='Mar 21 2007, 05:35 PM
Mine is booked in for next monday - to resolve an SOS Error message. This will need re-programming a new CTU but there is no gurantee it will be a Progman 25.00
I should get a 325 Cope here as a loaner
SO
I had it booked - at a different dealer - on the 4th of April for the iPod skipping issue
they booked me a 2007 525i loaner
SO
![Devil](https://5series.net/forums/images/smilies/imported/devil.gif)
ABC
#34
Originally Posted by aybeesea' post='407953' date='Mar 28 2007, 09:19 AM
We assume the first appointment didn't provide you with Progman 25 ![Think](https://5series.net/forums/images/smilies/imported/think.gif)
ABC
ABC
ABC you are right, it didn't
![Ermm](https://5series.net/forums/images/smilies/imported/ermm.gif)
So looking forward for the next Wednesday appointment
This time, I will make sure to mention that the ipod is skipping tracks after switch off. MAybe this will push them to ask for a V25.0 upgrade
#35
If you go armed with one of the symptons below, this should ensure you get it.
This Service Information bulletin supersedes S.I. B61 14 03 dated December 2006.
designates changes to this revision
SUBJECT
Software Errors Corrected with Progman
MODEL
E60, E61 (5 Series)
E63, E64 (6 Series)
Vehicles produced up to February 28, 2007
SITUATION
Customer may complain of the following:
The following software errors were corrected with the release of Progman 25.00.00 (Target data Status E060-07-03-510).
Engine pinging and cold idle fluctuation complaints. A jolt may be felt under braking. Only N62TU.
CCC: The programmable diamond MFL button does not work when set to "Next entertainment source" when vehicle is in motion.
CCC: The customer occasionally has poor radio reception after the vehicle was programmed with Progman V23.x or V24.x.
The speedometer and tachometer needles shake when the vehicle is idling.
CCC: Slow response to inputs made when using controller after startup.
CCC: A high frequency whistling noise intermittently can been heard in radio mode
CCC: Navigation system pop-up arrow display missing. Refer to SI B84 61 06.
CCC: CD/CDC track advances after key cycled. Refer to SI B65 32 05.
SUBJECT
MODEL
E60, E61 (5 Series)
E63, E64 (6 Series)
SITUATION
#36
So the car is back from the dealer.
S.O.S error resolved
Progmman 25.0 installed
I won't go into the details of the Progmman 25.0 as it has been covered extensively before. But I just wanted to withdraw my previous comment concerning the colours of the i-drive menus.
From the photos posted before, it did look dull(er) and more faded than the vibrant colours for pre - progmman 25.0. However, after seeing it in the flesh, I think they are very good actually, and not as faded as the posted photos show them to be.
