Problems with V8 Motor
My Ride: BMW e60 525IA 12/2003
Hi
Have some of you V8 4.0L ( and V8 3.5L ) owner's ever experienced that when the car ( engine )is cold , that it seems that one or two Cylinders not are runnig properly ? , when the car have been driven for a short time , turned off , and then started again , then it runs as it should , it's only in the first cold phase that there are problems with uneven engine time.
I have valvetronicen suspect that soot by those who are causing the problem, is there anyone who has any experience with this problem, any help will be received with gratitude
My Ride: See my signature
Hi
My Ride: 2008 550i Sport (6-speed)
I have experienced rough idle when the ambient temperature drops (as in winter below 50 degrees F) combined with the car not having been started for a couple of days. No check engine light ever came on and the rough idle went away by the time I'm at the stop sign just down the street.
I was told by BMW North America this is not normal. My 550i goes in on Tue to the dealer so a BMW engineer can take a look. I found a SIB about a software upgrade that fixes it. I will let you know what BMW does.
Hi guy's
Thank you for your message, we have so far tried the following.
When the error occurs and the engine running rough, so light engine lamp in the speedometer, as I said, if we after a little ride, stop the engine and start again, then the error is disapered and the engine running smoothly thereafter.
Decommissioned cylinder head and cleaned the cylinder head, valves and piston tops of soot.
We have also tried with an updated engine software , that diden't solve the problem either
We will try and look for the SIB you mentioned , please let us know what you come up with after your visit to the BMW dealership "izzE60".
If any one else have an idear , please "tune" in
Thanks in advance
![Cool](https://5series.net/forums/images/smilies/cool.gif)
![Nono](https://5series.net/forums/images/smilies/imported/nono.gif)
![Help](https://5series.net/forums/images/smilies/imported/help.gif)
Thanks in advance
My Ride: 2005 545i Sport 6MT
Rough Idle cold can be caused by uneven filling of the cylinders due to the valvetronic intermediate levers. There is TIS bulletin about this issue. The problem is fixed by replacing these levers.
thesalboy
04-08-2015 09:13 AM
Thomas the Swede
09-13-2003 12:22 PM
