problem solved; engine 525D not reaching operating temperature.
#301
My Ride: E61, 530D, 2005
Vista, I'm tomorrow changing out both thermostats. No warranty tough. I've to pay myself.
I've exactly the same symptoms like you plus auxiliary heating taking long time to get the car warmed up. Last winter the process was much faster. I also recognize not hot but warm air is flaying out from the heating vents, even after pretty long drive.
The car gets relatively fast to 60 but next is barely getting 75. Rather stays at 70ish. This is with no question NO GOOD AT ALL.
On top of all the happy stories with changing thermostats here I can point a few more from a Polish forum. Most, if not all, guys are getting 90 with new thermostats.
We'll see how that works for me tomorrow. I'll definitely posts results.
#302
Sounds like your symptoms are identical to mine.
I wonder how many other owners are driving around in ignorance of this because BMW chose not to fit a temperature gauge on the dash. :thumbsdown:
#303
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
Sound like my problem too, on stationary gets about 98 degrees but on drive drops to 60.
I have the main thermostat and plan to change it tomorrow, but after reading this I will change them both. If someone is interested I can try to make some pictures and post it as kind of DIY. I can't promise, but I can try
#304
I've not collected the car yet. Due to terrible weather condition the garage didn't revive the ordered water pump to be replaced as the preventive maintenance. The car has 130K. In my previous Bimer the pump died at 140K.
What I can report is that they've found the main thermostat broken. It stays open.
#305
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights
Planned mods:
Folding mirrors - Modmynav kit - High gloss shadowline trim -
#306
The annoying flaps are the 6 that are inside the intake manifold, if you are unlucky they can come loose and destroy your engine. Basically they are little butterfly flaps that open and close similar to a throttle body, they dont serve any purpose that i am aware of. BMW wont do a recall as it doesnt affect enough people, when it goes it is very expensive to put right. I wouldnt remove the grill flaps, they actually assist the car in warming up.
#308
Model Year: 2011
Changed them on Saturday, first I decided to change only the EGR thermostat, because it was much easier and tested - but after 20 miles driving it was not more than 70 degrees, so I had to change main thermostat as well, easy job, but one of the thermostat bolts broke in middle, so I had to take the water pump out and take it of, when I had the pump out I decided to change it for new one. Job done, car is reaching the temperature within 10-15 minutes - city drive, on idle is holding 90 for 30 minutes without any problem.
Just I'm not sure about independent or auxiliary heater - do I have one? I had E39 530d and X5 3.0d before and both of them had an auxiliary
heater, but I can here any sound than I have one or there is something like that working. I saw somewhere on the forum there is an electric one? Does someone knows more about it?
If there is one, is it possible to switch it on before I enter the car? Like on timer? I have the option to switch something on, but it is blowing only cold air or my heater just doesn't work?
#309
In order to check if you have an auxiliary heating fitted, go in I-Drive to Climate and next as per pic
If you see selector called Independent Heating then you have it.
#310
Thanks for the feedback. I'm still getting stonewalled by my local dealer on this and can see it dragging on unless I change them myself or fund changing of them myself. Pretty disappointing from BMW really
