problem solved; engine 525D not reaching operating temperature.
#151
Originally Posted by Bob525D' post='826403' date='Mar 25 2009, 06:25 PM
Thank to Mini Me for starting this thread, I now have my car back with the new main stat fitted. My carnow reaches operating temp of 90-91 very quickly, and from what i have seen so far the mpg have drastically improved. I will have a clearer idea once I have run it to work and back a couple of times. Thats a beer and a dram I owe you Mini Me, give me a shout if you are ever in Scotland.
If im ever in scotland (which i would love) ill just might drop by
For that beer (and then some).
Cheers!
#152
My Ride: BMW E61 525DSE Auto Touring.
2004 54 plate
Metalic saffire Black,
Active Steering.
18 Inch Style 124 Alloys,
falken 452s
Beige Leather
Dark Poplar Wood Trim
xenon bulb upgrade
blutooth phone prep
mini me
when you changed egr therm did you have to bleed the system
i know the stat has a bleed screw but do you bleed with
engine running or off
cheers
cheers
#153
Originally Posted by hey3688' post='826465' date='Mar 25 2009, 07:07 PM
mini me
cheers
cheers
There was hardly any air in the system though.
#154
2004 54 plate
Active Steering.
falken 452s
Beige Leather
xenon bulb upgrade
blutooth phone prep
Originally Posted by mini_me' post='826511' date='Mar 25 2009, 06:47 PM
I bled the system with the engine running and only used the screw on top of the EGR therm.
#155
Anyone else wondering how big this is?
Also how much to replace both thermostats is the way to go first with the EGR (exhaust gas recovery in case anyone else is was wondering) or the main thermostat?
#157
Originally Posted by parmblagan' post='799296' date='Feb 23 2009, 12:57 PM
hi guys
i have this problem with low MPG with my car (average through town is 20 MPG from auto 525D 2005) want to get it solved as its costing me a packet. i have had a new air mass sensor put in and the MPG remains the same. had it remapped but the mpg remains the same. so after reading this topic i checked the temp. of my car and it gets to max of 84-86 depending on my speed, but usually takes about a 6 mile journey to acheive these temperatures.
this week end i removed the egr thermo, and exaimed it. i too can blow air through it.
so my question is my car is getting up to 84-86 but i can blow through the EGR thermo, do i need to replace it?
hi guys
been following this thread now for some weeks now. i have changed the EGR Thermo on my car and checked the temp. it seems to reach 90+ but it does take a while for it reach these kind of temps, maybe a good 10 mile run. today drove 2.9 miles and the car only reached 76 deg. with ambient temp of 10 deg.
thinking that my poor mpg is more than likely due to some problem to with temp of the car, maybe the main thermo is likely to be faulty. how can i check this out? does it cost a lot to put right?
and can some explain what is DPF REGENRATION, what does it do? how can i tell it works on my car?
#158
Originally Posted by parmblagan' post='827120' date='Mar 26 2009, 12:16 PM
hi guys
If you're only driving 2.9 miles then it's not going to get up very far. Remember diesels do run cooler than petrol engines anyway.
My car currently only gets to 82C and takes at least 10 miles to get to 76 deg (believe my main stat is broken).
When you say 20mpg through town, are we talking London grid lock or 30mph flowing town traffic? How long are your journeys? If it's the former I'd say that isn't too bad. If it's the latter then I'd say there's a probem, unless you're doing sub 10 mile trips. However, I personally don't think it's temperature related.
#159
Originally Posted by Stephen F' post='826105' date='Mar 25 2009, 10:04 AM
Hi,
I use Specialist Cars BMW in Stevenage and have done since 2004
I have had a long list of problems with my current car so know the staff at the service desk quite well, it has been in several times previously for poor fuel consumption at the same time as other issues. The service desk, the techs and the service manager have always been very helpful but unable to solve the MPG problem.
I am always very calm and polite with the staff no matter how frustated I am with the damn car - this makes a huge difference.
My car had previoulsy attained good mpg and the techs were aware of this, when I read about the EGR thermostat and cool running issue I investigated and found my car to be running cool.
As I have the BMW insured warranty with a ?100 excess I bought the thermostat myself for ?22 and spent the 10 mins fitting it. It made quite a difference but still not up to temp so I popped in to the dealer mid afternoon when I knew it would be quiet and showed them the broken EGR thermostat, explaining whole thing and that I initially got the info from a BMW forum
One of the techs (paul I think) came and had a look at it and immediately agreed that cool running would mean poor MPG stating the car should ruN at 90-91c and was surprised at the failed EGR thermostat stating he had never had to change one but stated that a failed open thermostat would not show up on the diagnostics.
I mentioned that it was still not attaining full running temp and the main thermostat was probably also faulty, he agreed that this was probably correct as there is no other reason for the car to run cool so they agreed to order a new main thermostat and do the work under warranty.
My car also doing DPF regeneration every 400-450 miles
On collecting the car I was informed the tech had driven the car before and after to confirm the temp readings and was really pleased the problem had finally been solved with the car now reaching normal temp very quickly.
I was asked to run the car for a few tanks and to let them know how it was going.
The thermostat problem is clearly affecting a lot of cars with very few being resolved as most are undetected, I would suggest trying a different dealer or even Specialist Cars at Stevenage, speak to Jim at the service desk and he will know all about it.
Or get your dealer techs to contact Specialist Cars to confirm changing the thermostat cured the cool running on my car.
My MPG is now 37 with mixed short journeys compared to 27-28 before the thermostats were changed!!!
On the motorway it will now sit above 40mpg where it used to refuse to go above 30mpg.
Solving this problem will save countless wasted visits to dealers and a lot of frustration for owners and dealer service departments
Do you have a BMW or a third party warranty??
Not sure how you would get on if it is a third party warranty.
Please feel free to PM me and leave your phone number and I will give you a call if you need any more info
Stephen
Stephen
Stephen - you're a star!
Phoned Jim at Specialist Cars Stevenage and my car is now booked in for replacement of the main thermostat under warranty!
They're also going to look into a slight vibration I have - he mentioned knowing of heat shields coming loose which is what it sounds like so he seems to know his stuff.
Getting it done on 9th April as that's when I'm going up to Peterborough again. I'll let you know how I get on.
#160
Originally Posted by parmblagan' post='827120' date='Mar 26 2009, 01:16 PM
hi guys
In the morning my 525D will also take about 10MLS to reach 91 (it is rock solid at 91 after that).
As said the 6cil 525D is a larger diesel engine and this combined with the fact that modern DI diesel have higher efficiency (thus lower heat production) you will never reach
operating temps in just a few miles of normal driving.
