Problem shifting into 3rd
Old Dec 5, 2004 | 10:23 PM
BlackBear's Avatar
My Ride: 750i
Model Year: 2014
Hi,
Under full acceleration when shifting from 2nd to 3rd it feels like the DSC is taking lots of power away just when releasing the clutch. There might even be some breaking applied.
What can I do to avoid that? It is somewhat bothersome. I noticed this in Europe but had forgotten all about it.
Old Dec 5, 2004 | 11:16 PM
Jimbo's Avatar
Please input your location in your profile. It helps in answering your questions.
Sounds like a trip to the dealer in instore. Maybe a software update would take care of this.
Old Dec 6, 2004 | 01:07 AM
JDN's Avatar
JDN
Do yo have the 6-speed? Could be the CDV.
Old Dec 6, 2004 | 09:20 AM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
[snapback]65377[/snapback]
That's probably it.
Old Dec 6, 2004 | 10:34 AM
SueBMW's Avatar
We've got the problem. But the dealer won't fix it or acknowledge it is a problem. Our clutch sticks & even ended up burning out at 7k miles, and they still won't admit in writing there is a problem.
Old Dec 6, 2004 | 10:39 AM
zippers525's Avatar
I ahve the same problems. My car judders/slips while engaugeing first gear. I also have troble putting the shifter into first. Sometimes i have to double clutch. I downloaded TIS and have service bullitens now I wonder what they will say next time i bring it in. My SA never calls me back. 3 calls already
Old Dec 6, 2004 | 11:07 AM
SueBMW's Avatar
[snapback]65584[/snapback]
Sorry to hear it, but glad to see someone else has the same problem. They told me that it was acceptable to need to double clutch to put it in first gear & reverse gear-- it was actually "expected" with this transmission. I'm sorry, but I don't EXPECT any expensive car to need to be double clutched!!! I also need to use two hands to pull it into gear sometimes because it is so stiff. I've been in 9 times for this problem now (as well as a host of other problems each time). The furthest I got was the FSE drove the car, verbally admitted there was an issue, but said they wouldn't fix it and made the dealer put "no fault found" on the R.O..
Old Dec 6, 2004 | 11:58 AM
zippers525's Avatar
Later when i get the chance ill put all the service bullitens i found up. It goes over the procedure to fix the first gear and hard shifting problems. It also goes over the slips. There are 3 or 4 of them.
Old Dec 6, 2004 | 12:43 PM
SueBMW's Avatar
[snapback]65623[/snapback]
I would GREATLY appreciate that. That's what 2004RType or whatever his name was promised me and never came through on. It would be extremely helpful to have the bulletins so I can show them something.
Old Dec 6, 2004 | 02:08 PM
heezy545i's Avatar
Originally Posted by BlackBear' date='Dec 5 2004, 11:23 PM
Hi,
What can I do to avoid that?? It is somewhat bothersome.? I noticed this in Europe but had forgotten all about it.
[snapback]65339[/snapback]
DSC prevents tires from slipping so I don't believe you have problems as this appears to be DSC at work. The same situation occurs during hard acceleration form 1st to 2nd, yes?
The problem can be fully avoided if you turn DSC/DTC off. Or perhaps faster shifts or a better balance between the clutch and shifter would help.
I still have my CDV in at the moment. I ordered the modified CDV, but have yet to have it replaced.
