Problem: idle RPM not OK
My Ride: 2004 E60 Bi-Fuel
Business Navigation
Park distance control
Sunroof
extended airco with armrest
18" M5 rims with Runflats
xbox with 2 headrests LCD
front LCD video enabled
Detachable towbar
Alarm
anti-blind rearview mirror
Adaptive Xenon
Bluetooth carkit
Garage door opener integrated
Headlight cleaning system
Seat heating front
Guys,
I have a 520 petrol, and my engine revs since this morning between 800rpm and 1100rpm, it alternates between these rpm. with a frequence of about 2 seconds.
Like 800 .....one second .....1100.....one second.....800
Yesterday the idle rpm's was around 600 rpm
Is there a problem with the lambda sensor? Does anyone had the same problem?
I like to try to solve it myself before I go to the dealer.
by 800 and 1100 rpm, i assume you mean below the 1 mark and just a bit above the 1 mark. On my car it always idle at about 1100 rpm as well, so i assume its normal. below that and the car will kind of vibrate like its about to choke and engine stall...
Sounds more like Idle Control Valve/Sensor being a bit dirty. Part 8 in diagram below. Clean with brake cleaner or electrical component cleaner; should be an easy DIY job, but I don't know your specific engine that well.
http://www.realoem.com/bmw/showparts.do?mo...hg=11&fg=40
Business Navigation
Sunroof
Detachable towbar
Alarm
Adaptive Xenon
Bluetooth carkit
Seat heating front
Thanks for the info....
If the car is definitely hunting (i.e. the revs DO go up and down), then look at the ICV/ICS. If it's just the needle shaking but the engine rpm are stable, I think it's the problem pointed at in the SIB above. Good opportunity to have the latest bugs - erm, I mean software - installed
![Winkcool](https://5series.net/forums/images/smilies/imported/winkcool.gif)
ucsbwsr
09-19-2015 10:58 AM
