PROBLEM WITH BATTERY DISCHARGE 06 e60
Hello guys i have 06 bmw 530i. it discharges battery and couldnt find the problem. I bought the car like that.
when I check with the multimeter. settting 10A. i get the reading .21 (continuous drain) when everything is shut from + terminal . is it normal or it should be less.
I tried pulling out all the fuses but still no luck.
thanks for your help
how long have you had the car? How old is the battery? Are there any other electrical componenets (non-OEM) on the vehicle?
My Ride: E60 M5, F85 X5M
Read my experiences with a similar problem here: https://5series.net/forums/topic/998...nt-find-cause/
It was ultimately the TCU (Telematics Control Unit) that needed replacing as it would wake up intermittently and not allow the car to go into sleep mode so I would get a high battery drain warning every morning.
Do you receive any error messages? Do you have a scan tool to use to read any codes? If so, what are the errors that appear?
It may be that you'll have to find an independent shop or a dealer that will be able to diagnose the problem appropriately for you.
It could be that you one of your software programs has a bug and will need to be reset or updated.
In the meantime why don't you disconnect the terminals on the battery and leave them off for a few hours. Reconnect them and see what happens.
If this does not help, you can add a trickle charger (1.5amp) battery tender to the battery so that it doesn't constantly lose the power until you get it diagnosed. Wait for others' opinions. Good luck.
My Ride: 2006 530i sport/premium package, Black and Tan
2000 528i premium package, Black and Tan
Awest91
09-17-2022 11:05 PM
DavaiLave
08-02-2022 02:16 AM
