problem with air distribution system <--AC
Old Nov 15, 2004 | 10:06 PM
VaSh9394's Avatar
My Ride: 2005 BMW 545I SMG, Black Sapphire Metallic, Anthracite Maple Wood Trim, Cold Weather Pkg, Logic 7 Pkg, Sport Pkg, BMW Nav Pkg, HUD Pkg, Gargo Liner.
I'm having this weird problem with the ac system whenever i push the middle button to turn off the ac or heat. the middle button off led would light up but after i turn off the car and start it again the ac or heat would be on the first green bar??? is everybody having this problem??? i can't seem to turn it off for good.
Old Nov 15, 2004 | 10:51 PM
mlist84's Avatar
As i remember, the car will remember the last position of your AC (if you have level 1 to max) when you turn off your car. But the car will set it up to level 1 if you off the AC before turning off your car.
I will check it again to confirm.
Old Nov 15, 2004 | 11:56 PM
browellm's Avatar
AFAIR, this is one of the car key memory settings that the dealer can change
Old Nov 16, 2004 | 07:36 AM
VaSh9394's Avatar
[snapback]56685[/snapback]
that sound kinda lame. if this is true my memory should be off since this was my last setting before turning off the car. Please confirm Thank you in advance
Old Nov 16, 2004 | 07:53 AM
Guest
Guest
Posts: n/a
I had this problem and the dealer either fixed in with a software upgrade or key coding change...
Old Nov 16, 2004 | 08:11 AM
juan2mini's Avatar
VaSh9394:
Welcome to the forum. Do you have the climate set to "auto" default in the i-drive. I believe the "auto" setting will cause this situation. Just uncheck the "auto" box in the climate setting and see if it helps. Once again, welcome.
Old Nov 16, 2004 | 09:16 AM
VaSh9394's Avatar
Originally Posted by juan2mini' date='Nov 16 2004, 01:11 PM
VaSh9394:
[snapback]56812[/snapback]
Thanks this is the best 5 series forum
let me double check but I'm sure idrive dont have ac on auto.
Old Nov 16, 2004 | 10:07 AM
pharding's Avatar
My Ride: 11 550i Sophisto Gray/Oyster Black/Anthracite, Sprt Trns, DHP, IAS, SP, PP1, PP2, CWP, HUD, DAP, AVSP, SF RS, CA, ACC - Euro Del
The AC button should never be set to off permanently. One of its purposes is to dehumidify the air in the car so it's more comfortable. The AC also helps to keep your windows from fogging up.
Old Nov 16, 2004 | 10:18 AM
juan2mini's Avatar
Mine is always set to off, except in the rare case when I need ac or heat. I am sure in Chicago the weather, summer humidity - winter cold, makes leaving the system on the best option. I have had my car over a year, I have used the ac a couple of times on long trips. Around home cracking the window works fine. My .02
Old Nov 16, 2004 | 11:36 AM
DXXXi's Avatar
My Ride: 530i, Silver Grey, Black Dakota, Steptronic, Premium, PDC, Logic7
Mine too. I try to use the A/C as little as possible. I find that the problem with using the A/C to dehumidify the car is that once you start doing so, you have to do it all the time. If you try to stop using it on a cool day, the A/C releases all of the moisture it contains and fogs the windshield badly.
