Problem with acceleration
Old 03-29-2015, 03:59 PM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
It could have a slight influence on the drive but should not be enough to trigger the light i would think. When was the last brake fluid flush? Have you tried the acceleration in all modes to see if it is only happening in Normal mode? I would say that since you are not getting a steady light your ABS module and sensors are good but I would still check all sensors (they are blue in the wheel well). Did you check information messages too? That could give you some information too if you did not check them.
Old 03-29-2015, 04:07 PM
Model Year: 05 530i
Engine: 3.0 M54
Sorry the IM selection is in the trans module
Old 03-29-2015, 05:18 PM
Impac's Avatar
My Ride: 2008 BMW E60 535i
Model Year: 535i 2008
Brake fluid has never been flashed , I checked in all modes and as I can tell problem is in only Normal mode. I checked Information massage board and everything is OK mode , what would the brake fluid do with this I chacked the fluid level and it is in Normal fill stage meaning Ok level.
tis66
05-18-2021 08:59 PM
cinergi
08-03-2018 04:31 PM
Faizd
04-27-2015 12:16 PM
Steve J
04-17-2015 08:10 PM
Thomas the Swede
09-13-2003 12:22 PM
Quick Reply: Problem with acceleration
