Problem with 2005 545i - again and again
Old 03-24-2010, 02:23 PM
krzyschicago's Avatar
Thank you guys for the input! I guess I will start wirth autozone
Old 03-24-2010, 02:40 PM
obacht545's Avatar
Originally Posted by salaki
Go to Costco or local Harbor Freight tools and get OBD2 or OBDII sensor:
http://search.harborfreight.com/cpis...BDII&Submit=Go
Costco has one for $30 I think.
Plug it into your OBDII port to check the P Codes.
The code will give you an idea of what problem you have before handing $100 "diag" fee to dealer.
+ 1. Picked mine up from Costco for $30 and worked like a charm on my wife's Audi allroad. Was able to tell the tech exactly what's wrong (down to which bank sensor was having issues) and he was appreciative. Saved $130 diagnosis fee, thingy already paid for itself.
Old 03-24-2010, 04:45 PM
Ok, so Costco right after Autozone
Old 03-24-2010, 05:35 PM
spandex's Avatar
Have a look at this SIB... Sounds very familiar, although technically it's only supposed to apply to 2003/2004 cars:
SIB 11 03 06
There's a 'repair kit' for the work in this SIB which is less than $20 per side I think.
Old 03-24-2010, 07:28 PM
gdillon's Avatar
My Ride: 2005 545i
I had the same error message with check engine light staying lit, on my 05 545i. Per my invoice, the fault code was 2EF4 [T-SAT MECHANISM STUCKED] It turned out to be the thermostat was sticking in the open position so they replaced it. Yours maybe a different issue as there can multiple increased emissions light along with check engine faults.
Old 03-25-2010, 05:04 AM
Were there some other symptoms or just the lights?
Old 03-25-2010, 07:42 AM
gdillon's Avatar
My Ride: 2005 545i
Only thing I noticed was the engine idled slightly rougher but it wasn't a big noticeable difference.
Old 03-25-2010, 08:01 AM
gdillon's Avatar
My Ride: 2005 545i
Let me clarify that last statement. When the check engine light and message came on I drove the car for 3-4 days until I could get it in for a service. During that period only abnormal issue I noticed was the engine idled slightly rougher a few times. Now, I don't like driving with warning lights on so maybe I was being over sensitive to any slight difference in the car's behavior. I mentioned this to my SA and he said the V8 can idle rough periodically and it was not a problem.
Old 03-25-2010, 09:40 AM
I also hate to drive with the check engine light on but I will have to wait till next week to get it checked and fixed.
I think I also experience rougher idle but it may be due to my imagination
Old 03-25-2010, 12:42 PM
rafichicago's Avatar
My Ride: 2008 BMW 550i M Sport
B.S !!! Engine should run smoothly with no vibration and certainly not rough. Change Your SA.
Quick Reply: Problem with 2005 545i - again and again
