Power steering hose leaking at dynamic drive pump
Probation Members
My Ride: 2008 535 i BMW
Engine: 3.0 twin turbo
My 2008 535 I BMW is leaking power steering fluid out of the high pressure line at the Dynamic Drive connections, it appears to have got a hole in it, how do I replace it ? I purchased a line but came without instructions. Where is the connection point on the other end ? It leaks all over our garage when parking, and we get an Dynamic driving warning ( roll over caution ) and low power steering fluid warning .
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Maybe I'm not getting what you're asking. You bought the line but don't know where it is to install it? I would say find the line you purchased that is already installed in the car and unbolt from both ends then install the new one in reverse order.
Yeah intermittent problems are the worst to troubleshoot. My indy mechanic just tells me to come back if or when the problem gets worse.
