Post LM2 swap angel eyes and AHL not working. Faulty LM2?
2005 545i with both adaptive and xenon headlights from factory
Just completed a retrofit for lci adaptive xenon headlights from the pre-lci adaptive xenons, getting an error for angel eyes, AHL, and the front right cornering light. All bulbs could be powered through the headlights connector using a separate 12v battery. The wiring harness on the headlight end was only giving 0.04 - 0.07 volts to the angel eye circuit when activated, everything was wired coded correctly, according to the retrofit pdf and multiple videos. Could this be a faulty LM2 module? I bought the module used off ebay and recoded the mileage and vin through ncsexpert.
EDIT: The angel eyes worked for about 30 seconds then turned off until I restarted the car, then the cycle would loop. This was about a week ago and now the angel eyes won't work whatsoever. Welcome lights aren't working whatsoever either anymore and would work intermittently before when the angel eyes would turn off.
Reason: More information
