Please help with air in the master cylinder
My Ride: E 60 5 series BMW
Engine: N52
I did the stupidity of suck too much brake fluid from the master cylinder, when flushing the lines,
How do i bleed the master cylinder, is any bleeding screw?
E60 525 i 2007
E60 525 i 2007
My Ride: 535i M Sport
Model Year: 2010
Yes, you'll have to bleed every corner of the car in the proper sequence and pray that there's no air trapped in the ABS/DSC unit. If there is air trapped in the unit, you'll need either INPA or ISTA to activate the DSC bleed procedure otherwise your brakes will be spongy no mater how many times you attempt to mechanically bleed them.
motopokep
DIY: Do It Yourself
16
06-19-2010 06:06 PM
