Please Help
Old 07-24-2012, 02:41 PM
  #21
balbs's Avatar
My Ride: BMW
Originally Posted by StormTrooper
Thank you for all the replies. I just started the car and the messages are gone. Then, I took it out for drive 15 minutes later the messages reappeared. Now the new dilemma is battery replacement. There's so many threads regarding battery getting register or not.
Also, pay attention to what you were doing when the warning appeared. Were you moving the steering wheel even just a little?
I had this issue and it turned out to be the steering angle sensor in the SZL. Here's another test...next time you get the error while driving, start making turns where you have to use the turn signal. Does the turn signal turn itself off after the turn or do you have to turn it off yourself. If you have to turn it off yourself, it's the sensor because it doesn't know how much you are turning the steering wheel.
BTW, I had the SZL replaced on my car because of this error.
Also, I hear that something along the brakes, maybe ABS sensor can cause this issue as well.
Old 07-24-2012, 07:16 PM
  #22
StormTrooper's Avatar
My Ride: 2008 550i Alpine White
I was on my way out of a parking garage when it happened. I had to make a few turns, but I m not sure if it came on when I was turning. Knock on wood, I really hope it's just a weak battery. Thank you for your input. I'll keep the steering angle sensor in mind.
Old 07-24-2012, 07:29 PM
  #23
sanjsanj's Avatar
My Ride: E60 530d
fyi, i noticed a spike whenever my warnings popped up, so that was more confirmation it was an electrical issue. Try and keep an eye on the voltage the moment the warning comes on.
Old 07-24-2012, 10:01 PM
  #24
luilui41's Avatar
I believe that as long as the battery has the same specs as your old battery, you're fine without registering it (crossing fingers cause I changed mine myself about 3 weeks ago and everything seems fine so far)
Old 07-30-2012, 05:38 PM
  #25
[quote name='luilui41' timestamp='1343196107' post='1459113']
Update: i got the battery tested, autozone voltimeter stated it was weak. So I got a new battery today at autozone (duralast gold). Everything seems fine, all I had to do was adjust time and date. A short drive home, same warnings came back. Well at least I now know its not the battery that threw the errors.
Old 07-30-2012, 07:21 PM
  #26
Giowizzy's Avatar
Reading the cost for a battery plus programming it got me thinking for real..... Thats half for a body kit on this 1 stupid battery hmmm that hurts. Imma start looking for the DIY.
Good luck and keep us posted though on how u managed.
Old 07-30-2012, 08:13 PM
  #27
Originally Posted by Giowizzy' timestamp='[url="tel:1343704917"
1343704917[/url]' post='1460260]
I got the battery for $135.00. I might as well get it programmed at the dealer along with the errors. I'm going to wait a few more days and see if it all goes away I'll keep you guys posted.
Old 08-03-2012, 12:07 PM
  #28
bens1088's Avatar
I have the same errors pop up every once in a while. Took it to an indy and, as suspected, steering angle sensor.
I was quoted $500 just for the part.
