persistant rattles
My Ride: 2004 BMW 545i
I get a ton of rattles after letting the car sit either after work or during the first drive. the rattles are mostly from the center pillar where the seat belts are. it's especially noticeable when the car is going over bumps. i know when i had my Acura TL the dealership did things to get the rattles out from loose parts under warranty. would bmw do the same?
You did not metion what model and year car you have?
Check out the following SIB, it could be your solution.
http://www.bmwtis.com/tsb/bulletins/bullet...mp/B510205g.htm
yup i have a 2004 545. looks like this is my exact problem. I'm going to call my dealership early tomorrow and see if i could drop it off right away. THANKS!
My Ride: 2004 545
Originally Posted by billeul' post='459441' date='Aug 16 2007, 03:09 PM
Worked for me. Also had the dealer readjust the rear seat back to eliminate a major creak that appeared to be coming from the rear shelf. Good luck.
PelicanParts.com
08-10-2015 01:55 PM
srogers535x
08-05-2015 08:48 AM
