Peeling paint on window control panel & steering wheel
#41
While the rep from BMWNA is still trying to contact a dealer closer to my work to see if they can make a courtesy replacement of peeling parts in my car, I called another dealer in the area they said they would be glad to replace ALL the peeling parts under warranty! So, guess, where I am taking my car...
It is really weird to see one dealer saying no, the other saying yes to the same request...
#42
I've had some trim pieces replaced and others declined. It was a difference in SA and how each presented the case to BMWNA I believe.
As to SIBs on the subject: So far only found a 3 & 7 series
SI B51 21 07
Body Equipment October 2007
Technical Service
PERFORM THE PROCEDURE OUTLINED IN THIS SERVICE INFORMATION ON ALL AFFECTED VEHICLES BEFORE CUSTOMER DELIVERY OR THE NEXT TIME THEY ARE IN THE SHOP FOR MAINTENANCE OR REPAIRS.
SUBJECT
Service Action: Replace the Door Panel
MODEL
E65, E66 (7 Series)
SITUATION
A required hardening agent was not applied to the door panel. As a result, the surface finish could peel off the door panel.
CAUSE
An error in the manufacturing process of the door panel.
AFFECTED VEHICLES
This Service Action involves select E65 and E66 vehicles which were produced from 7/25/2007 to 7/27/2007.
SI B 51 18 06
Body Equipment May 2007
Technical Service
This Service Information bulletin supersedes S.I. B51 18 06 dated August 2006.
designates changes to this revision
SUBJECT
Interior Door Grab Handle Peeling
MODEL
E90, E91, E92, E93 (3 Series)
SITUATION
The painted surface finish on the interior door grab handle may peel off due to exposure to certain hand creams and sun-tanning lotions.
CORRECTION
On a customer complaint basis, the armrest (left-front door) or door panel (right-front and rear doors) should be replaced. The following procedure should only be carried out on the affected grab handle(s) which are confirmed to be peeling.
PROCEDURE
Left-front door grab handle:
Replace the armrest per repair instruction RA 51 41 081.
Right-front or rear door[s] grab handle:
Replace door panel in accordance with repair instruction RA 5141001 (front door) or RA 5142001 (rear doors).
SI B51 21 07
Technical Service
SUBJECT
MODEL
E65, E66 (7 Series)
SITUATION
CAUSE
AFFECTED VEHICLES
SI B 51 18 06
Technical Service
SUBJECT
MODEL
SITUATION
CORRECTION
PROCEDURE
#43
Ok, just came back from my local dealer (those who said no before) and talked them into replacing the window switch panel which is peeling off badly... It is thanks to this forum have I been able to do that! And even though they said no to the temeperature dial (again, it would require replaceing the whole center unit, over $1K parts and labor), I am thankful for that.
I want to thank this forum for participation, geting me enough arguments to present to the dealer, and just for being out there... Dealers are aware of that!
- One, now happy, BMW driver
#44
My Ride: 2004 525i M Sport Automatic, M Sports Package, Bi-Xenons, Sunroof, Hot Climate Version, Navigation+TV, 18" Double Spoke 135M Alloys with Runflats, Anthracite Headliner, M Leather Steering Wheel. Through Load System, Hifi Loudspeaker System, Alu Cube Pure Interior Trim, Flashlight Cloth/Nappa Leather Sports Seats, M Sports Suspension
Same thing happend to my M Sports Steering wheel. Got annoyed with it, scraped the whole paintwork off where the peeling is at, the lower spokes and spray painted it silver to match the Alu Cube Pure interior trim.
#45
I just had my Sport steering wheel insert and 2 door handles replaced on my X5, no questions asked.All pieces were showing wear marks. Only 40,000KM!!!!! Must be a faulty process for applying this dark covering on these surfaces.
Cheers
Cheers
#46
I thought this might have been a problem associated with my '05 touring having done 157k miles in 3 and a half years and was prepared to give BMW interior trim quality the benefit of the doubt, but it looks like I was wrong to!
The worst affected parts on mine are the window switch panel, the door pull and the steering column shroud. The steering wheel has a few tiny marks but I can live with them. If respraying these parts is an option, I might just give that a go if I can find the right paint.
#48
My Ride: 05 545 BLK/BLK
Model Year: 2005
I just had mine replaced for free. My car is still under warranty. I just told them about it, and they replaced it no problem. it was only on the Driver's side window control switch.
#49
I've also had several panels replaced for this problem, drivers side window switch, plate behind stereo volume knob.
No questions asked by dealer, in fact they acknowledged it was a common problem and fixed it right away. I do live in Fl...high humidity and heat.
I have some pealing going on now around the power seat controls so I'm hopeful they will replace these as well before my warranty expires.
#50
My Ride: 2007 Sapphire Black Metallic 525i. Beige Dakota Leather, Premium package, bluetooth, BMW Assist, Xenon adaptive lights, Sirius radio
Originally Posted by tonye60' post='342835' date='Oct 8 2006, 11:34 AM
it peeled of above my passanger window switch and the silver was coming of the gear stick
Please call- : 1-800-831-1117.
I have had 2 pieces on my steering wheel replaced 2 power window plates, 2 door pulls ( behind the wood) and the area surrounding the a/c controls. Everyone said I must be using hand cream or my fingernails are too long, or it is cologne. What it is is unacceptable plastics on a 50,000 dollar car.
