.PDF's and/or detail sheets
Old Dec 4, 2012 | 12:02 PM
D3aThRoW's Avatar
Default .PDF's and/or detail sheets
Any one know where i can get the .PDF's or detail sheets like the one below?
Mainly looking for the detail sheet for my LCI Halogen headlights because i am installing HID's.
I have a 2009 528i and i need a few of these to remove/reinstall a few things.
Thank you very much in advance
Old Dec 4, 2012 | 07:49 PM
AchtungE60's Avatar
My Ride: E60 530i
Here you go
RealOEM.com * Diagram Selection
But go look in the DIY section to find out what you need. It's all been done before
Old Dec 5, 2012 | 06:09 AM
D3aThRoW's Avatar
Originally Posted by AchtungE60
Here you go
thank you..
and i did look in the DIY section to see if anyone has done HID's to Halogens but only found one and it wasnt very informative :/
but thank you none-the-less.
Old Dec 5, 2012 | 10:28 AM
AchtungE60's Avatar
My Ride: E60 530i
There are plenty of threads discussing this even if there are no DIY's. This is an expensive project and will require reprogramming of your LM2 (LCI light module)
Old Dec 5, 2012 | 12:33 PM
D3aThRoW's Avatar
WAIT!! I have to mess with programming just to add HID's to my lights?
i thought that was only necessary if i replaced my LCI-Halogen headlights to Xenon equipped headlights.... ????
Old Dec 9, 2012 | 05:10 PM
AchtungE60's Avatar
My Ride: E60 530i
You said you have LCI halo right? So if you are going to go with LCI xenon then you have to buy the lamps. You can't just stick some xenons in there. The headlight is different. Also the options that are on the vehicle order need to be changed and the options that the LM2 are putting out need to be changed.
Old Dec 9, 2012 | 05:11 PM
AchtungE60's Avatar
My Ride: E60 530i
Now if you want to put a simple aftermarket HID kit on your car that's a different story. But don't expect there to not be errors.
Old Dec 10, 2012 | 06:01 AM
D3aThRoW's Avatar
OH! gotcha... Im just putting in after market HID's in with canceller's for no error codes.
for a minute there you scarred me. lol
Thanks for the info!
andymax
May 20, 2018 11:32 AM
bestofthebest
Mar 28, 2016 02:47 PM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
ucsbwsr
Sep 19, 2015 10:58 AM
DetailersDomain
Detailing Forum
Sep 3, 2015 07:08 PM
