PDC, Reverse light, mirror tilt not Working when in reverse
Hi Everyone,
I can't find any post regarding the above.
When in reverse the PDC suppose to go on and passenger mirror tilting down,
None works. All fuses ok, gearbox switch changed bulbs tested and are ok.
Does anyone knows where PDC reverse light and Tilt mirror connect? An what color is the reverse light wire?
O, and the mirror side switch is on Driver side.
Thank you.
BMW 520i 2004
Thank you.
BMW 520i 2004
