pdc
Old Jan 10, 2010 | 10:33 PM
podcauro's Avatar
pdc on e6o doesnt work.. any ideas????
Old Jan 10, 2010 | 11:08 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
could you be a little more vague?
Old Jan 11, 2010 | 05:22 AM
DD_545i's Avatar
Especially in the subject line. It's marginally better than those that have the subject line of "help!".
Many more details are needed for anyone to offer suggestions.
Old Jan 11, 2010 | 07:42 AM
podcauro's Avatar
hi there. One of the front sensor failed to work in cold weather,but no PDC FAILURE was showen.. I tryied to open it from outside(was using screwdriver)... Anyway, i couldnt open it and warning message came on straight away.. DID I DAMAGE THE ACTUAL SENSOR? is it pricy job????
Old Jan 11, 2010 | 08:55 AM
BlaSTiWi's Avatar
Its quite common for PDC sensor to behave strangely in cold weather especially if there's frozen moisture ... the sensor is actually pop inward as oppose to outward (after you undo the clip behind the bumper) ... the fact that it wasn't set off any PDC warning before and after mocking around w/ screwdriver now there's warning ... yes ... quite possible you damage it during the process.
Each sensor maybe not that pricy but labor to replace it maybe, depend on the location it may require bumper removal or atleast the front grill or headlight ... to be exact check with your dealer.
GL!
Vman33
Mar 14, 2022 04:43 AM
Trinity Autosport
Sep 22, 2016 11:08 PM
bestofthebest
Jan 5, 2016 07:47 PM
mlopez7353
Sep 27, 2015 04:53 AM
Gadamsm5
E60 M5 Discussion
Sep 15, 2015 11:43 AM
