Parking lights, warning light on dashboard..
Old Nov 20, 2011 | 04:57 PM
ta201ace's Avatar
My Ride: BMW 525D M Sport
Hi everyone, i have these parking light faults on my dash, it states that my parking llights have falied but they are working!! What can i do to remove these errors,
Has anyone else got the same problem? Cheers
Old Nov 20, 2011 | 05:53 PM
jaycal3's Avatar
My Ride: 04' 545i, Sport Package, Black, Active Xenon, ARS, Aux Input '10 Tahoe, Black on Black, leather, Nav/XM, 20" tires, full body kit, power 2nd row, loaded '93 Jeep Wrangler, lifted 4.5", 33" meats, Rampage Recovery Bumper w/Tire Swing, etc 25' Aquasport Osprey, Center Console,2012 200 HO Etec
Are your AE's on?
Old Nov 20, 2011 | 07:09 PM
AchtungE60's Avatar
My Ride: E60 530i
No never had that issue. if your parking lights are in fact on, i'd look at the halos like the previous poster said. They're tied in.
Old Nov 21, 2011 | 01:31 AM
ta201ace's Avatar
The halo's are working too, whats AE's??
Old Nov 21, 2011 | 08:14 AM
rocksteady530's Avatar
Halo's = AE [Angel Eyes]
I had that issue, at first everything seemed ok then a few days later as I pulled into the garage I saw the right side Halo/AE flickering. It eventually went out. Replaced them.
It could also be loose connection - you can try checking that first.
Old Nov 25, 2011 | 02:00 AM
ta201ace's Avatar
Oright once i change the AE would the warning lights go off?
Old Nov 25, 2011 | 06:39 AM
vkhong's Avatar
Model Year: 2010
I would re-seat the bulbs in the rear lights first. While you're at it, look for corrosion on bulb contacts (bulb and bulb holder). This is easier and may resolve the warning light issue. You'll need diagnostic software to tell exactly which parking light bulb is causing the error.
Old Nov 25, 2011 | 04:15 PM
devildawg712's Avatar
My Ride: 545 modded the F out
does the warning come on as soon as you start the car or randomly after driving? It very well could be a that your AE bulb is a little loose and breaks 100% contact during the drive because of a sudden bump or shutter just long enough to trigger the error.
reseating the AE is what I would try first.
Old Nov 26, 2011 | 06:15 AM
ta201ace's Avatar
The error is their when i start the car. So i will try reseating the AE bulbs. Will i need to remove the headlight to reseat AE bulbs?
Old Nov 27, 2011 | 11:02 AM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
It's advisable too, unless you have magical hands that can fit and interface with extremely tight space.
