Parking brake is very loose and doesnt work
My Ride: Bmw 530d 2004
1) Lift the rear wheel(s) up
2) Remove rear wheel(s)
3) Turn the wheel hub in a position where one of the wheel bolt holes is on the lowest point possible
4) Look at through the hole with a torch and you'll see a little gearwheel inside the hub. The teeth of the wheel are facing outside towards you through the hole.
5) Put a screwdriver in and turn the gearwheel up (it should tighten the handbrake when turning up if I remember it right).
The above is a common guide how to do it. However, it could be a good idea to loosen the gearwheel at first, then hit the hub with a hammer and blow some pressured air inside (through the wheel bolt holes) to loosen the dirt on handbrake shoes. Then tighten it up as much as it goes. At this point try to turn the wheel hub. If it's locked, there's still something left of the brake shoes lol! Then loosen the gearwheel just a bit. Repeat on other side. If the wheel hub doesn't lock when the gearwheel is tightened up, you probably need new handbrake shoes.
- Antti -
- Antti -
My Ride: 02/2006 525i Titanium Silver Metallic
Manual 6-Speed
Here is an example: https://5series.net/forums/topic/124...1#entry1451360
My Ride: BMW 550i
Model Year: 2011
Hello All,
I am having the same issue with my handbrake. I followed Antti's instructions above and with the rear tires off the ground, the tires lock and hold with the gearwheel adjusted all the way up. So I loosen it just a little and the wheel moves freely, however with the tires on the ground, the handbrake is not holding the car at all once pulled. So I have a couple of questions.
1. What position should the handbrake be when adjusting the brake shoe gearwheel?
2. How do I adjust the cable tension on the handbrake itself?
Thank you.
Thank you.
My Ride: 09 550i 6sp M-Tech. 18mm spacers rear, 8mm front. Dinan intake and Stage 2 tune. Tinted tails, M5 OEM lip spoiler.
08 Z4 3.0si Black on Black with Beige top. Removable hardtop. (Hers)
06 Volvo S60R Heavily Modded!! Gone and missed.
They dont get replaced on a normal brake pad replacement. There inside the rear brake disk,
RealOEM.com * BMW E60 530i PARKING BRAKE/BRAKE SHOES
Hello All,
Thank you.
Thank you.
Lever should be in the down position. The cable is not adjusted, it's the shoes that are adjusted. They are self adjusting so if doing what is mentioned above doesnt work, then your'e out of meat and it's time to replace linings.
You also have to do a 'bed in' on the e-brake from time to time. While driving at about 50 kph, pull the brake until you feel some drag, pull it 2 more clicks and drive for a block then release. It'll work better after that.
My Ride: 545i sport
And you live in Houston so they WILL faiil you during inspection if the brake doesnt hold.
Awest91
09-17-2022 11:05 PM
DavaiLave
08-02-2022 02:16 AM
TexaZ3
05-06-2015 09:54 AM
BigxPx
04-23-2015 10:11 AM
