Parked Car Operation Settings
My Ride: E60
I'm a little confused by something...
Under "Parked Car Operation", I have a couple settings listed. One indicates "activate time" or something like that. The other indicates "automatic ventilation". When I choose a time under "Activate time", what am I activating? I always thought it was the "Automatic Ventilation". But when I go to actually select "Automatic Ventilation", it's gray'd out. When I try to chose it with Voice Commands, it indicates "Mode Unavailable" or something like that.
Can someone enlighten me on this whole thing? I have selected two start times and checked the boxes. But why is "Automatic Ventilation" gray'd out?
Thanks all...
Thanks all...
My Ride: G30 M550i
Model Year: 2018
The two start times will work at the preset time. The automatic ventilation setting is an on-demand function that allows you to turn on the blower right away. It's grayed out if the key is in position two.
Turn the key to position one and the grey will dissapear...
My Ride: E60
Thanks for the info, Rudy.
-Jonathan
-Jonathan
Originally Posted by Rudy' date='May 26 2005, 12:18 PM
The two start times will work at the preset time.? The automatic ventilation setting is an on-demand function that allows you to turn on the blower right away.? It's grayed out if the key is in position two.
[snapback]133457[/snapback]
Every time I examine "Parked Car Operation", the times are unchecked. In other words, the two start times will cycle through only one time, and not again until you re-check again.
Is this normal?
Is this normal?
Originally Posted by wnrussell' date='Jun 14 2005, 04:43 PM
Every time I examine "Parked Car Operation", the times are unchecked.? In other words, the two start times will cycle through only one time, and not again until you re-check again.
Is this normal?
Is this normal?
[snapback]139526[/snapback]
My Ride: 2001 BMW330ci, Steel Gray, Black leather, Steptronic, PP, SP, PDC, Heated seats, Xenon head lights, HK, 6 disk changer, OEM alarm, OEM clears,Iice white fog lights ,Universal trasnciver, 17 inch Michelin Pilot Sport Tires
2005 530i Titanium Gray,Black leather, Nav.,HUD,PP,CWP,SP,PDC,Xenon lights,Steptronic,Logic 7 sound system,,Fold down read seats,Power shades
ON ORDER
Originally Posted by itcrashed' date='Jun 14 2005, 08:53 PM
[quote name='wnrussell' date='Jun 14 2005, 04:43 PM']Every time I examine "Parked Car Operation", the times are unchecked.? In other words, the two start times will cycle through only one time, and not again until you re-check again.
Is this normal?
Is this normal?
[snapback]139548[/snapback]
[/quote]How long does the fan run before it shuts off on each setting??
cheers
vern
So p;lease enlight me...what is Parked Car Operation really used for beside the self description. Here in florida is 95 degrees and anything comming out of the vents without ac is not going to ventilate me...
