Overnight battery drain...IBS sensor
Old 08-02-2011, 05:55 AM
  #21
545felix's Avatar
My Ride: 05 545/6
Originally Posted by Deano
So if I pull the connector off of the TCU, and the stereo goes to sleep, then I should replace the TCU?
yes
I remember there was a relay built into the technic harness. Is this the "hi-lo adapter?
yes, that's it. Speaker level to RCA level, hence hi-lo.
Is there a way to determine if the amp that is built into the headunit is sleeping while the MS-8 stays awake? If I force the MS-8 to sleep it will turn off the other amps as well, but if headunit amp doesn't sleep I'll still have a draining problem.
unfortunately I don't think so unless you measure draw at the headunit harness or have access to a diagnostic device (GT1 etc)
Old 05-08-2015, 05:29 PM
  #22
patallen's Avatar
My Ride: 530xi
i am digging into this too...lots of things to read. i have one questions
can the IBS alone could cause the car to NOT go into sleep.
thanks.
BBoy123 (09-12-2020)
Old 11-22-2015, 05:52 PM
  #23
NguyenAzn's Avatar
My Ride: 525i
Hey guys,
My oem bat dead and i replaced it with an after market same specs battery. The shop did register the battery and everything. Everything was fine untill i left it over night and try to start in the cold monring. I mean the car would start fine but it pops up " intensive battery discharge " and tells me to set the time. So i try to took the IBS sensor off and i got no more error message. But i measure the battery after a 1 hour drive from 12.6 something drops down to 12.25 over night. Is this normal at all ?
Old 11-24-2015, 06:31 PM
  #24
BimmerFan52's Avatar
Disconnecting the IBS and then having no more discharge will tell you that the IBS is damaged and needs to be replaced (most common in cars 2004-2007 when the IBS construction allowed moisture damage).
However, disconnecting the IBS and then still having discharge tells you it isn't the IBS. You also remove monitoring of the battery so even if the IBS wasn't the problem you have also removed monitoring and won't see the warning light as the charge drops because the IBS isn't there to measure it.
Dropping from 12.6V to 12.25 is not normal overnight.
I assume you have check for easy solutions like aftermarket wiring for radar detectors, stereos and even bluetooth modules left plugged into the OBDII port.
Later model E60s have had problems with comfort access door handles.
Old 09-12-2020, 05:20 PM
  #25
BBoy123's Avatar
My Ride: bmw 530i 2004
Default 2004 e60 battery draining overnight
Originally Posted by EuroCarFan
I and a couple other M5 owners had a similar problem and after checking/changing things like the IBS, Comfort Access (CAS) module, door sensors..etc..they narrowed it down to a faulty Telematics Control Unit (TCU) which was keeping the car from going to sleep and draining the battery over night. Some people say one way to check is to turn off the car but maybe sit inside of it and wait to see if you hear noises from modules still staying on. Another way is if the shift indicator light on your shifter is still lit.
Hope you sort things out and that it won't be too costly.
Hi, I am new to this group and I am having same problem. New battery died just overnight 😪. When I turn off Car, I sit inside and I hear always 3 sounds in a very straight order Repeatedly! Also the Light on my shifter stays ON. What to do, Help?
Old 09-12-2020, 07:51 PM
  #26
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
Regarding the car not going to sleep and the battery drains, why not connect the amps to the female cigarette outlet port in the trunk.
This is the outlet in the trunk for auxiliary light or tire pump.
We know this port is not live when the car is off.
Old 09-13-2020, 11:30 AM
  #27
EuroCarFan's Avatar
My Ride: E60 M5, F85 X5M
I haven't been on this site in ages but I'd probably check the IBIS first and then the comfort access module.
ianbmwe60
12-03-2014 10:47 AM
Ardent
07-12-2012 12:35 PM
Tex735
09-26-2010 09:07 PM
gregg2gs
06-09-2010 07:28 AM
nevrev73
03-27-2010 05:20 AM
Quick Reply: Overnight battery drain...IBS sensor
