Overheated
bought a new water pump and thermostat -_- and it still overheated and i checked the head gasket and its perfectly fine! soo wtttthay yo help me out here peeps
My Ride: 2006 BMW 550i
who installed the pump and t-stat?
was the cooling system properly bled when refilled?
if all else looks good, is it possible the t-stat is stuck open? what was your original problem?
LOL. Right? And what would you go through all the trouble of checking the head gasket for? Are you saying that you had a coolant leak? Check to make sure that your system is bled properly. Air in the system will be an issue. It very well may be your thermostat as well. Why did you buy a new water pump etc etc....Sounds like we're missing part of the story.
