One Touch Window close.
Originally Posted by GENEaTALS' post='1097527' date='Jan 25 2010, 08:54 AM
no way to disable the anti-trap function via iDrive in my '08/LCI e60 either ![](http://www.e90post.com/forums/images/smilies/iono.gif)
Originally Posted by GENEaTALS' post='1097527' date='Jan 25 2010, 11:54 AM
are you sure you performed it correctly? did the windows roll all the way up and all the way down on their own after you went thru the process? That's how i knew I did not perform the reset correctly the first 2 times....
no way to disable the anti-trap function via iDrive in my '08/LCI e60 either![](http://www.e90post.com/forums/images/smilies/iono.gif)
Yup did it 3 times still nothing. Strange
Originally Posted by EBMCS03' post='1097685' date='Jan 25 2010, 11:59 AM
Prob not a US thing... they wont let us chop of a criminals arms if they try reaching into our car...
My Ride: 2006 titanium silver metallic
Like new 41k
Cold Weather Package
I had the same problem. Reset never worked. They replaced the window motor under warranty and it has been all good since.
![Cool](https://5series.net/forums/images/smilies/cool.gif)
1-Turn key to second position (radio on)
2-keep pressing down (2 clicks, press all the way) to open the window all the way
3-keep it pressed till the warning sign in your dashboard appears (Anti-trap sign with an exclamation mark). Unless this icon shows, keep pressing.
4-As soon as the sign shows, click up(2 clicks, all the way up) till the window closes. Do not remove your finger UNTIL the anti-trap sign goes away from your dashboard. THEN, you have had resetted your window.
Hope it works.
Originally Posted by Bteljuice' post='1097851' date='Jan 25 2010, 06:08 PM
in order for mine to work, I had to wait a little while longer so try to follow my procedure(which is almost the same):
Hope it works.
Hope it works.
Ok will try that tomorrow morning. I Will let you know how it goes.
And I am Canadian too!! Wish it worked.
<div class='quotetop'>QUOTE (Bteljuice @ Jan 25 2010, 06:08 PM) <{POST_SNAPBACK}></div><div class='quotemain'>in order for mine to work, I had to wait a little while longer so try to follow my procedure(which is almost the same):
Hope it works.</div>
Re did it today. Went smooth as thought, except windows still does it periodically. Guess its livable
My Ride: 2004 530i Titanium Silver. (6spd)(Sport)(Premium)(Navi)(Active Steering)(Adaptive Headlights)
umichchris
09-10-2015 12:54 PM
