Old battery experiment
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
What would happen if you had a 4 year old battery and went through the INPA registration process and registered it as new?
My Ride: 2009 528i xdrive
In theory, it would attempt to charge it at an incorrect rate. Why not simply buy another battery? Depending on what you have, not a bad idea to replace them every 4 to 5 years as preventative maintenence
My Ride: 528i
Engine: N52k
If a 4 year old battery was inadvertently registered as new with INPA, you mentioned in theory, it would attempt to charge the battery at an incorrect rate.
Many people have bought new car batteries that have been sitting around for months and did not hold a full charge when installed. When those batteries were registered with INPA or other scanners:
a) how did the BMW charging system know the correct rate to charge the depleted battery?
b) when a battery is 4 years old and has always been on a Delran trickle charger with a full charge, how does the BMW charging system know the proper rate to charge the old battery?
Go ahead and try the experiment and see! After all, you presumably "know" what the "true" state of the battery is and won't be surprised if problems come up later.
