Oil vacuum
When using a vacuum device to suck out the oil, you'd normally use the dipstick tube. Since the E60 (well, mine anyway) doesn't have a dipstick, what should be used? Is it OK to use the fill hole or the oil return (seen when you remove the filter)?
I searched but didn't find anything that addressed this specifically. Thanks!
Vacuum ? Why not drain ??
I also have an oil vacuum. It worked great on previous cars, but without a dipstick I think it is useless.
You won't be able to vacuum from the oil filler hole. The vacuum tub has to go down to base of oil pan. There is no access from the oil filler to the bottom of the block.
I too would appreciate if someone has figured out a different solution (besides crawling under the car to drain the oil).
My Ride: 2005 e60 Titanium grey Auburn premium Sport 6-speed Logic-7 folding rear seats with ski bag Bi-xenon Cold weather package
because the filler is in the head, and the pan is under the block.
