oil leaking underneath engine
Old 08-12-2013, 08:56 AM
elie7's Avatar
My Ride: E60
Default oil leaking underneath engine
Hi! I found this oil leaking underneath car and not sure what to expect when I bring the car for repair. Please tell me what needs to be done and and idea the cost of repair. Many thanks again.
Old 08-12-2013, 09:08 AM
Maini's Avatar
My Ride: 535
Model Year: 2010
Who is your Indy in By Area??? I use European Auto Repair in Sunnyvale
Old 08-12-2013, 09:18 AM
elie7's Avatar
My Ride: E60
I just went to European Car Service lately at el camino real, san bruno city for brake fluid flush for decent $75.
Old 08-12-2013, 12:08 PM
elie7's Avatar
My Ride: E60
anybody?
Old 08-12-2013, 02:55 PM
e6t.lab.rat's Avatar
More info on type of e60 and location of the pics would help.
I'm assuming that is the ac compressor we see with the connectors?
Old 08-12-2013, 03:16 PM
elie7's Avatar
My Ride: E60
car is 2006 530i sport. I think its next to the transmission and ac compressor. thanks
Old 08-12-2013, 04:39 PM
I'm not at all familiar with inline 6's but if it's anything like the V8's, then it could be the the vacuum pump or the oil pressure switch. These two are notorious for leaking in the V8's and is directly above the AC compressor. My leak was very similar to yours, with oil all over the bottom of my AC comp and swaybars. Found out my oil pressure switch went bad. So I replaced with a new one and now the garage floor remains spot free. Good luck
Old 08-12-2013, 06:49 PM
dbond's Avatar
This is electric water pump in N52 engine. The pump obviously is not the source of the leak. Get a flashlight and look above the pump.
Old 08-17-2013, 07:53 AM
L337E60's Avatar
My Ride: 550i MSport
Model Year: 2010
Engine: S54
Your oil filter housing gasket is leaking oil. The oil eventually makes it down by the water pump area and this is what you will see. Ask me how I know...
Old 08-19-2013, 02:11 PM
elie7's Avatar
My Ride: E60
Just wanted to give you update that the oil leaking is coming from oil housing gasket. My mechanic is charging me $262 for the repair. Thanks
Quick Reply: oil leaking underneath engine
