Oil check
Old 04-15-2018, 01:41 AM
Bimmerlat's Avatar
My Ride: E60 545i stock
Default Oil check
New here
need some advise on this,computer indicates oil level ok car drive good but no oil on dipstick.
I've checked numerous time adding a bit of oil still no oil on dipstick any ideas?
Old 04-15-2018, 05:33 AM
E60I's Avatar
My Ride: 2006 BMW 530I
Model Year: 530i
When was the last time you had an oil change? If you have not done so lately, I would change it (with recommended amount ) with a new oil filter; so you know you have enough in there.
While you are under the car, use a good flash light and look for leaks. If there are no indication of leaks, then you know you have recommended amount of oil in your engine. Are there black smoke, coming out from your tail pipe? Check the oil filter housing gasket and crankcase vent hoses for leaks.
I don't recommend keep filling up the oil, just because there is no oil in the deep stick (?). Overfilling with oil is also bad for your engine!
Good luck!
Originally Posted by Bimmerlat
New here
Old 04-15-2018, 09:11 AM
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
New here
The computer on the 2004 545 only indicates oil service intervals (at least that is what my 2005 545 shows), not the oil level, so I am not sure what you mean by "computer indicates oil level ok". If the dipstick indicates low oil, add some until you see a level on the stick. The dipstick is the more reliable indicator at any rate.
Old 04-16-2018, 04:32 AM
Bimmerlat's Avatar
thanks for the replies I will take photo and show what computer indicates havnt uploaded anything yet on this forum so i will try. I will also do an oil change but it's been like this since I bought the car
1 year. No apparent oil leaks either.well nothing major apart from oil stains on the bottom cover
Old 04-16-2018, 09:44 AM
Bimmerlat's Avatar
Here are some images
Attached Thumbnails Oil check-20180416_182036.jpg   Oil check-20180416_182045.jpg
Old 04-16-2018, 10:24 AM
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
You have service data called up in idrive. This reflects how long until your next oil/filter change under BMW's condition based service. This has nothing to do with the oil level in the engine. Use the red handeled oil dipstick, which is located on the passenger side, with right hand drive English equipped cars, of the n62 engine, back toward the firewall. Please top off your oil using the oil dipstick to determine proper quantity.
Old 04-16-2018, 11:24 AM
Model Year: 2005
Engine: N62
In fact, if you see no level on the dipstick, then you can put in 1 litre of oil with no fear of putting too much. The amount of oil between the upper and lower marks is about 1 litre.
Old 04-16-2018, 11:29 AM
Bimmerlat's Avatar
Ok will do asap thanks
Old 04-17-2018, 01:46 AM
Bimmerlat's Avatar
quick question why don't I get a warning light if my oil
is low?
Old 04-17-2018, 05:56 AM
Model Year: 2005
Engine: N62
is low?
There is no warning light for low level oil, only for low oil Pressure. It appears that you have been fortunate in not having low oil pressure in spite of the apparent low level of oil.
Quick Reply: Oil check
