OEM Wheels That Fit XI?
My Ride: 08 535xi
there are many websites that sell oem replica, is that what you are looking for?
Either way. You need an ET of 35-40.
It is possible to run a staggered set up (wider in rear) but I went with square set up for my 08 535xi. You just have to make sure that your wheel/tire diameter is very very close to the same all the way around. If you run wider wheels/tires in the rear, the tires will have to be lower profile.
I am running 245/40/19 on my car.
Hope this helps.
Hope this helps.
![Exclamation](https://5series.net/forums/images/icons/icon4.gif)
![Welcome](https://5series.net/forums/images/smilies/imported/welcome.gif)
https://5series.net/forums/tires-whe...ions-xi-95139/
Recent thread based on a simple search 'bout the same thing = https://5series.net/forums/tires-whe...wheels-133687/
My Ride: 523i
If I may: 16", 17" and some 18" wheels on E60 cars use ET20 wheels. I can't speak for the post facelift (LCI) model but I can confidently say that '05/'06 E60's would use ET20 wheels unless staggered or 19" and above.
check this link out
5 Series (E60/E61) wheels
Paul
check this link out
Paul
Hope this helps.
Hope this helps.
My Ride: 2006 530xi w/Sport, Premium, Cold weather. Silver Gray Metallic, Black Dakota leather interior.
check this link out
Paul
check this link out
Paul
