OEM M Parallels on E60/E60
Thanks for your reply!
I would suggest test fitting them. The offsets may not work directly, which would mean you'll need spacers. Also, depending on which model they came from, you will want to check the bore size of the hub. Our cars use hubcentric wheels, which just means there's a lip on the hub where the wheel sits. previous years of BMWs had different bore sizes and that would mean that you'd need hubcentric rings to make the wheels fit properly.
Virak1985
07-07-2015 10:43 PM
