OCCUPANCY SENSOR BYPASS UNIT
Guys I have searched to the best of my ability and find the answers I need.I am trying to figure out how to wire this in I purchased one awhile but but cant find the instructions and the seller on feebay is no longer.The E60 has a 3 wire setup and the E39 was only a 2 wire setup if ANYONE has any info on theses or can point me in the right direction I would be very grateful.
The extended recall covers a lot of cars for the passenger set mat. Did you check to see if yours is covered?
Curious if the car has been properly diagnosed and the seat mat was determined to be faulty. I know there are several components that can provide the same indication. I guess, what I am saying is that it would really suck to install this work around then find it doesn't do what you thought it would.
My Ride: 2007 E60 2004 M3
Yes. With the bypass the airbag will always deploy. The bypass has 2 devices to plug in: 1) seat mat emulator and 2) seatbelt simulator. I plugged the seat at emulator and the airbag disabled light turned off sink assume airbag is active. I haven't located the seatbelt simulator plug yet so the chime still rings
murdock
07-04-2015 08:45 PM
