O NO!! my right rear wheel is bent inwards
My Ride: 08 550 Carbon Sport Almost everything factory, but no sound upgrades.
Not sure of what you are describing ... not enough probing here yet.
Are you describing toe angle or camber or wheel run out (wobble)?
Good link: http://www.ozebiz.com.au/racetech/theory/align.html
My Ride: E60 530d M-Sport
The possible things spring to mind, pardon the pun
Firstly, you have a broken or weak spring, this is dependant on how the geometry reacts to compression, most RWD cars add some toe in by design to the rear wheels as the arse end squats under acceleration, this also aids stability, does the static ride height of the car look any different from side to side ?? or just the toe angle ?
Secondly, a worn / perished bushing causing toe in
Thirdly, bent wishbones from a harsh impact - clonk on the kerb maybe ?
hmm all great advice....i got the alignment done and that seemed to have solve the problem. i still have some vibration, i was told all 4 of my wheels are bent.....might get those done now
Administrator
My Ride: 530xi
Engine: N52
Check the posting date, Safraz. As a newbie, you should know that we generally don't close threads around here because they contain valuable information, so don't expect a response when you post to an old thread, especially to particular members. Case in point is that this thread was started 9 years ago and the OP, aresh, hasn't been around for almost four of those years.
Welcome to the forum!
