noticable rough idle at start-up and when stopped,
My Ride: 530i
04 530i --- at start up after engine settles to 600 rpm idle there is a very noticable vibration as well as when stopped (i.e.; traffic light)
there is also a slight vibration when accelerating which dissipates when you "take your foot off the gas"
This all goes away after a bit of driving and does not happen throughout the day after car is "warmed up"
Coils, 02 sensors ?? not sure what problem is
any help appreciated and apologies if this has already been discussed
Last week I got into my car and it was running rough but when I accelerated it was okay
The next morning the same thing but I couldn't drive it
The funny thing was that I had no fault codes
I was thinking at first a plug or coil but no
Then a fuel pump or filter but no
It ended up being the "mass air flow sensor"
Luckily I had a spare and the car has been fine ever since
My Ride: 530i
thanks --- it's still there. You can hear a slight hum type noise in the cabin , rough idle may not be best description as the enginw itself seems to run fine and idles at 600 rpm ------ there is just something almost like a rubbing (hard to describe) if I am in drive at a stop I can depress brake and gas it up to 800 rpms or so the vibration goes away pretty stumped and don't really wnat to fork out $ to find out it may be a simple thing
ashanzx
Oct 26, 2017 12:51 AM
Brendan412
Oct 22, 2015 04:19 AM
nisonger212
May 23, 2007 02:08 PM
