Is this normal tire wear?
Old 10-31-2009, 05:15 PM
mrfva's Avatar
My Ride: .
Model Year: .
Originally Posted by sdg1871' post='1044413' date='Oct 31 2009, 08:11 PM
32 PSI seems quite low
Agreed, but I think he should be able to patch that tire up.
Canada545's Avatar
Originally Posted by sdg1871' post='1044413' date='Oct 31 2009, 07:11 PM
Well, 35,000 kilometers is 21,747 miles. That is a decent tire life for summer performance tires. I believe that you got that much because you did largely highway driving. As far as pressure goes, for my summer tires, I follow the BMW recommended PSI which for the 550i Sport with staggered setup is 36 PSI front and 44 PSI rear. 32 PSI seems quite low but I know nothing about what pressure RFTs should be inflated to. Look at this as a golden opportunity to ditch the numbflats for the much more comfortable non-RFT tires.
Really, 44 psi in the rears? Wow, I has have misread my manual because I thought 32 psi was correct ...
And yes, I'm going to go with non-RFT, perhaps the PS2's
Old 10-31-2009, 05:18 PM
mrfva's Avatar
My Ride: .
Model Year: .
It varies; people run different front/rear PSI.
I personally run 38F and 42R with my 245/35/19F and 285/30/19R tires on my 545i
Old 10-31-2009, 05:25 PM
DRANGED's Avatar
+1 Rears should be 4psi higher than the fronts.
Old 10-31-2009, 05:27 PM
tachyon's Avatar
Originally Posted by Canada545' post='1044406' date='Oct 31 2009, 08:03 PM
Most of my driving was highway ... heading to the golf course with 3 or 4 guys / clubs in the car.
And recommended tire pressures are even higher (+6 psi) when the vehicle is loaded down with multiple passengers and luggage.
Get the PS2s - they are outstanding.
Old 10-31-2009, 05:29 PM
sdg1871's Avatar
My Ride: See my signature
It could very well be that the recommended inflation pressures for RFTs are different than those for non-RFTs. For my summer tires, I go by the recommended pressures printed on the driver's side door.
As far as summer tires go, PS2s are one of the best price no object tires. They are not known for long tread life. But I have never met a PS2 owner who did not like them a lot.
Given how fast I blow through tires, I went with a much less expensive tire that has pretty equivalent performance to the PS2s (at least according to this summer's Car and Driver comparo and by rave reviews from some of our members): the Hankook Ventus V12 Evo. The Hankooks cost me $185 per rear tire from Tire Rack versus about $400 per rear tire for the PS2. Nonethless, if I had unlimited funds, I would have bought the PS2s.
Old 10-31-2009, 07:08 PM
SilberGrauE60's Avatar
Originally Posted by Canada545' post='1044396' date='Oct 31 2009, 06:49 PM
Is this an issue with the manufactory (Dunlop), an issue with the run flat tires, an issue with my e60 545 or is this normal?
1. This is an issue with OEM Dunlop RFTs, Dunlop SP Sport 01 DSST on the E60 5-Series cars. In the U.S., there was a service bulletin that covered replacement of all four tires if the owner complained of excessive tire noise or vibration and the tire exhibited the uneven wear pattern on the inner shoulder and the tires had less then 20,000 miles. See S.I. B36 02 05.
2. Recommended inflation pressures for the 18-inch Y-series tires: Front - 32-38 psi, Rear - 35-42 psi, depending on loading. So, min recommended pressure in the rears is 35 psi.
Old 11-01-2009, 01:37 AM
pjinca's Avatar
Originally Posted by sdg1871' post='1044399' date='Oct 31 2009, 04:51 PM
Good lord. My OEM non-RFT rear summer Contis wore evenly and I wore them down a lot. I wonder if you have an alignment problem.
It not an alignment problem Scott, my rears were much more cambered inward when I had the 125's on there than the 172's. the 172's seem to flatten out the negative camber much better than other wheels. With the 125's the negative camber was VERY noticeable, with the 172's? Barely perceptible.
Old 11-01-2009, 01:35 AM
KAF
KAF's Avatar
Model Year: 2015
Engine: N55
In the UK we have speed reduction measures called speed cushions.
These are speed 'humps' which do not cover the full width of the road, but are in each cariageway and are champfered at the sides, a bit like a short pyramid shape with a flat top.
The track width of many cars is such that they can drive over these and only the inside edges of the tyres ride over the raised angeld sides of the cushion, this has been known to cause severe wear of the inner tread/sidewall of tyres where the car is driven over them regularly.
The wear pattern is similar that that on your pictures.
Old 11-01-2009, 03:42 AM
sdg1871's Avatar
Interesting. The rear OEM summer Contis on my 172 wore very evenly. Shocking to see how much faster the inside of the OP's tires got shot.
Hmm, maybe this is another reason to keep your 172s.
Quick Reply: Is this normal tire wear?
