Noise under hood/pillar a right
Originally Posted by Palmo' post='824878' date='Mar 24 2009, 12:22 AM
Have you checked the torque of the Strut Brace Nuts if only to eliminate this?
My Ride: 2007 E61 M5, 1989 Z1
Originally Posted by dbm' post='825371' date='Mar 24 2009, 02:45 PM
Also changed 51 61 7 010 593 but nothing.
I have a clunk over sharp-edged bumps or rumble strips that I've finally tracked down. The bolts for the strut brace were tight but removing the brace made the noise go away. Thus I suspect that 51 61 7 010 593 is loose.
Originally Posted by Palmo' post='824520' date='Mar 23 2009, 11:49 AM
Are you guys sure the source of your noise isn't related to the following HERE!
Mine began to make a noise following an air-filter replacement - basically the nuts on the strut brace hadn't been done up to the correct torque. I couldn't pin point where the awful noise was coming from to begin with - first I thought it was the centre of the dash, then the left A Pillar and so on. Tightening the nuts 100% cured the problem - which is a well known fault.
This is great, thanks,
Originally Posted by phelix' post='885428' date='May 21 2009, 06:45 AM
What's involved in changing out that part?
I have that same clunk! Only going over speed bumps. Sounds like a thud as if my strut is bottoming out. I'll have to look into this. thanks
