My 04 545i freaked out last night. I was driving home on the freeway and the i-Drive went black and then it re-booted itself. Prior to this, I was using the voice commands to pass the time away during traffic.
I have no warning sounds now. There is no annoying seatbelt "bong", or lights on reminder. This could be a good thing. :D Unfortunately, my PDC does not sound now. I have the graphical image, but zero audible sound. Has anyone experienced this before? It's almost time for me to take it to the dealer for an oil service. Thanks |
Everything probably works fine again now.
Try it. ;) |
Same happened to me except there was no radio as well, problem was solved as an "update" from the dealer
Try it. ;) |
If this happens again, reset the CCC or turn off the engine and wait 15 mnutes before restarting it. ;)
Next time at the dealer, get a software update. |
I hope you are still under warranty b/c you might need to get your CCC replaced fairly soon.
:nono:
I had this happen to me a couple times and after a software update it never happened again. No CCC replacement was needed. ;) |
