No start
Old Oct 7, 2012 | 01:48 PM
skripter2k's Avatar
Default No start
Woke up to a car that won't start. All appropriate lights are on but no errors listed. It does not turn and I have ruled out battery after having it on a tender. It's a 530i 72k m54 any ideas ??
Old Oct 7, 2012 | 03:41 PM
BimmerFan52's Avatar
You have ruled out the battery after having it on the tender. Did you throw a multimeter on the battery to double check it for a bad cell?
Do you hear a click when you turn the key (starter solenoid engaging)? If not then either 12V is not getting to the solenoid or the solenoid is bad. There are a number of reasons that 12V would not be getting to the solenoid, including the IVM module, MPM module, other assorted modules, or a loose connection.
If you do hear a click when you turn the key then you can be 95% sure it is the starter.
If it is the starter you'll need to pull the intake manifold off to get at it. Not too bad a DIY. When you have removed the intake manifold you can check for 12V at the solenoid to starter connection before pulling the starter motor.
Awest91
Sep 17, 2022 11:05 PM
gergnang
Feb 2, 2021 07:29 AM
Stranger12
Jan 21, 2021 06:19 AM
gaz
May 29, 2015 06:11 AM
spitfire23
May 12, 2015 04:23 AM
