NO SOS = No traffic information Right?
Hi guys
I get an SOS failure message every time I start the car, was not bothering me much as I will sort it out when I get the car in for its next service, until I tried to check Traffic Information in the Sat Nav. I got a blank screen with a message (No reception!).
Are the SOS & Traffic information linked?
Your comments would be helpful, thanks everyone.
Ps I am in the UK (in case it is different here)
SOS is part of telematics (via GSM phone network).
TMC (traffic Message Channel) is via RDS (Radio Data System) FM tuner. In UK this is done via (only) Classic FM so if you have no Classic FM reception yu won't get TMC data either.
Check your TMC settings in IDrive too.
ABC
Originally Posted by aybeesea' post='363749' date='Dec 5 2006, 04:53 AM
Entirely different systems.
ABC
ABC
Will check i-drive setting & Classic FM reception and report back.
aybeesea, You were right - I needed to change the settings in I-Drive and have traffic Information back
That leaves the S.O.S failure message, which is apparently very common on the E60
Thanks again and what a great Forum
My Ride: 2001 BMW330ci, Steel Gray, Black leather, Steptronic, PP, SP, PDC, Heated seats, Xenon head lights, HK, 6 disk changer, OEM alarm, OEM clears,Iice white fog lights ,Universal trasnciver, 17 inch Michelin Pilot Sport Tires
2005 530i Titanium Gray,Black leather, Nav.,HUD,PP,CWP,SP,PDC,Xenon lights,Steptronic,Logic 7 sound system,,Fold down read seats,Power shades
ON ORDER
cheers
vern
My Ride: 2006 550i
Build date 11/2005
options include:
cold weather package/ convenience package/premium sound package/ sport package/sunshades/Navigation/ V3 cradle/ OE 166 wheels/M-tech upgrade/M rear spoiler/ racemesh m-tech grill/racemesh kidney grills/M5 mirrors/M5 steering wheel/ HID fog light conversion/ M5 SMG paddles
Originally Posted by vern' post='363821' date='Dec 5 2006, 06:04 AM
As for the SOS you need a new TCU Unit to make it work properly.Do a search, there is tons of information on the subject. Good luck
cheers
vern
cheers
vern
Matt,
SOS ins which part of TCU which is one of the nodes of MOST bus. There are a few possibilities that things went wrong:
1. TCU malfunction -> Check your BT if it works. If it does not your TCU might be malfunction and needs to be replaced
2. One of MOST node is disconnected from the ring like CD changer. If you take out CD changer, you'll have this message.
Good luck.
Good luck.
