No Reset option for Maintenance Lights only "OK"
My Ride: 545i
Hi Guys,
Iv got an issue that I was hoping you could help me out with. I have a 2004 545i with 83k that I have had for about a week now. When I purchased it all of the maintenance lights were on in Idrive and on the ! triangle on the cluster. The guy had informed me that the better recently died and he had not rest the lights. I drove the car home and smogged it that same day with no issues.
The next day I came out trying to reset the lights but the lights would reset using the method below. while I was trying to reset the lights I killed the battery. I pulled it out and it tested bad so I replaced it. I did not get the same battery and the new battery is not registered to this car yet.
https://www.youtube.com/watch?v=*****Ual5Vo
However the issue that I am experiencing all of the Maintenance lights are currently on and none of them will reset. I set the time and date through iDrive, went through cluster reset procedure but I never see the "Reset" option. The only thing I see is "ok" but this does not do anything. I also noticed the mileage for everything seems to be blank. In the drive menu it also says "it has been _ _ _ miles since your last" Here is video that I took of my car. Any help would be greatly appreciated.
_a_
My Ride: 545i
Iv tried many many times. I believe the difference here is every single maintenance light is on and none of them give the option of "Reset". I believe "OK" seems to be the issue and the mileage listed is always _ _ _ _ _.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Why is every light on. We're the services due. Have you changed the services in the iDrive. Is your odometer correct. If I'm correct you've changed your battery but you said not with the same specs. Is it at least a battery that can handle a BMW.
Model Year: 05 530i
Engine: 3.0 M54
Ok I just looked at the video. I thought it was a video of the reset procedure but it is of you showing your issue. First thing I noticed was your mileage next to 000.0. I've never seen that. Has some coding been done to it. You need to hook it up to a computer with INPA and reset the values. Once you reset the odometer you should be good. For some reason it is not seeing your mileage
Could the car be in Transport mode? That's a pre-delivery mode that does some strange things.
My Ride: 545i
The day I purchased the car guy had shown me the lights and told me the battery had recently died. I drove the car 50 miles that day, smogged and registered it in the same day. I let the car sit for a few days and the battery died. It was 6 years old and it tested bad so I replaced it with a Walmart Everstart H8 battery. My intentions were to register the new battery with the car.
Im not sure if the car has ever had any coding done to it. I purchased a $20 coding cable that didn't work at all for me so I returned it. Im bidding on a BPM cable on ebay right now so when I get it I will attempt to reset the odometer.
Thats interesting. The mileage on the car seems to match what the DMV has on record so I really hope this is on due to the battery issues.
My Ride: 545i
Alright guys some help would be greatly appreciated, I got INPA working but now Im not really sure what to reset. Any advice on what to reset would be greatly appreciated. Is there a master reset for everything?
So far Iv cleared the error memory but with no luck.
My Ride: bmw e60
Actually what you have is the tamper dot. And the cluster in your car is not your car cluster. The guy who sold you the car either now about that or he could be like you. The millage shown in the cluster is not matching what been stored in your car computer's or module.
I do have the same problem now because my cluster drain battery and keep the car awake. So I change the cluster with used one from the Junkyard. And now all the services record on idrive marked with yellow triangle.
Do some research for tamper dot. You'll find more information.
