NO HEAT!
Old 12-19-2011, 05:42 AM
lawnboy's Avatar
My Ride: 2005 BMW 545i
2 nights ago my heat decided to stop working for the most part on my 2005 545i with only 38,000 miles. now with the heat on both sides cranked the the maximum, i have ICE COLD air blowing out of the 2 passenger side vents and only LUKE WARM air blowing out of the driver's side vents. anybody else have this problem?
Old 12-19-2011, 06:11 AM
sanjsanj's Avatar
My Ride: E60 530d
[font="'Comic Sans MS"]have you adjusted the settings in Climate in iDrive?[/font]
Old 12-19-2011, 06:22 AM
iyaayas12's Avatar
My Ride: 06 530i
I would check my antifreeze levels. That flows from the motor to the heater core which gives the car heat. If its low then you may have air in the system and it might need to be bled or "burped" as some people call it. I would check the small things like mentioned above about the iDrive. Make sure that the small lines are red instead of blue. I know it sounds silly but its commonly over looked. Hope this helps
Old 12-19-2011, 08:28 AM
lawnboy's Avatar
someone mentioned this earlier...when i am in the menu, how do i change them from blue to red?
Old 12-19-2011, 11:46 AM
aharper's Avatar
Hop down and then over to the blue, then spin the iDrive wheel.
Old 12-19-2011, 12:25 PM
lawnboy's Avatar
what is the damn point of this function? if i want to adjust the temp, i would just use the dial. why do i have to have "red lines" in the idrive setting to get heat? i can guarantee come summer i'll think my a/c is dead because i don't have the "blue lines" showing
you can tell i've only owned japanese cars up until now
Old 12-19-2011, 12:43 PM
Gilgorm's Avatar
My Ride: 2012 535i X-driveSpace Grey/Black Dakota, Fineline Anthracite Trim; Executive Package (Rear View, Lumbar, Nav, Voice, SIRIUS, HiFi Pro) Technology Package (Hi Beam Assist, Lane Departure, Blind Spot Detection, Surround View) BMW Apps (Apps, Smart Pho
Model Year: 2012
The four blue, four red and one white bars have more control over temp than any other knob you may wish to tweak. In the fall, I use two red and in winter crank it up to four red. When summer comes and you have a crazy mix of hot and cold you'll remember to switch to four blue (or you can ask us here at the forum).
Old 12-19-2011, 01:16 PM
seanjordan's Avatar
My Ride: 05 BMW 530I
I just keep my temp in the center which is the one white line. Everything works just as I want it. If my A/C doesnt get cold enough in the winter then I give it a couple of red notches and vise versa when it is summer but never need to. Try that for a while and see if it works for you.
Old 12-19-2011, 01:41 PM
brooklynbmw's Avatar
replace your thermostat!!!!
Old 12-19-2011, 01:55 PM
jaycal3's Avatar
My Ride: 04' 545i, Sport Package, Black, Active Xenon, ARS, Aux Input '10 Tahoe, Black on Black, leather, Nav/XM, 20" tires, full body kit, power 2nd row, loaded '93 Jeep Wrangler, lifted 4.5", 33" meats, Rampage Recovery Bumper w/Tire Swing, etc 25' Aquasport Osprey, Center Console,2012 200 HO Etec
Where the heck does this come from when its clear the op doesn't even know how to check the idrive to adjust the temp distribution???
No disrespect OP but check your owners manual or look online for the functions your idrive contains... lots of stuff in there! I hope that was your problem. If not, check for codes.
