No brake squealing sound but red brake light replacement came on?
Old Jun 19, 2017 | 05:33 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
I thought they went by mileage. If the brakes were changed without replacing the sensors you would get that error message eventually. What year and make do you have.
Old Jun 19, 2017 | 06:48 PM
neoe60's Avatar
What if I "reset" the message in the iDrive? If it trips again, then we can narrow it down to being a faulty sensor?
BTW, does each wheel have its own sensor?
Old Jun 19, 2017 | 06:51 PM
neoe60's Avatar
2006 530xi
I had the brake pads, rotors and sensors on all 4 wheels replaced back in 2012. It was an independent mechanic. I'm pretty sure they reset the iDrive because I got it serviced due to the warning on the iDrive the first time.
However, I've been working from home except only coming into the office for meetings, so my mileage is pretty low. About 95K miles.
Old Jun 19, 2017 | 07:31 PM
I guess the good news is you know that your brake are ok. If they were done correctly and since it's been 5 years on the sensors I would look at those first. Just as stated before one or both could be faulty. Your brakes look like they have no more than 15k on them (still new from what I see). Replace the sensors and you should be fine. I would not replace the brakes
Old Jun 20, 2017 | 05:58 AM
audiophool's Avatar
My Ride: 535xi
This:
https://bentleypublishers.files.word....jpg%3Fw%3D510
There's a resistor in the sensor circuit (470 ohm IIRC). When the resistor is cut, the sensor trips.
Old Jun 20, 2017 | 07:10 AM
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
Originally Posted by audiophool
This:
In fact, I think that the sensor is the resistor or vice versa. As the sensor (resistor) wears down, the resistance goes down and the circuit acts accordingly, giving an approximation of the pad thickness. In this case, perhaps, there is a shorted wire giving no resistance.
Old Jun 21, 2017 | 07:07 AM
neoe60's Avatar
So, my friend helped me reset the brake pad warning in my iDrive last night. I'm going to drive it a few days and see if it trips again. If it does, then I'll replace the front sensor.
Old Jun 21, 2017 | 11:36 AM
Model Year: 2005
Engine: N62
Why just the front? Replace both and be finished.
Salut, Bob P.
Old Jun 21, 2017 | 01:27 PM
neoe60's Avatar
Salut, Bob P.
The iDrive message was only for the front sensor.
Old Jun 22, 2017 | 03:45 PM
E60Japanese's Avatar
My Ride: E60 2006 sedan auto
It's just a simple wire and clip into the back of the brake pad
One on the front left and rear right
You can change both in minutes but they trip for a reason because your bake pads are getting low
I hope you will fit new front pad
The sensor is simply a copper wire or metal that is broken when the pad is low
Don't play with safety
Put on new pads and sensors and drive safely
